Mowing Mowing the hills.
   / Mowing the hills. #1
pal21
Hello everyone. First time poster.
I need suggestions on the most practical machine for bush hog work on steep ground.
Here is my background. I'm on my 3rd tractor right now. 1st was a massy ferg. TO30 which I had for 20 years and served me quite well. Than I decided I needed a loader, so I picked up a Kubota L2550 which I had for about 8 years and came to like quite a bit. Then I went to a Ford 1715 because I needed a backhoe. The Ford is OK put I still miss the Kubota.
Now my needs have changed again. I have 90 acres in Western N.Carolina. About 50% wooded, the rest has been in pasture for the last who knows how long.
Keeping cattle is no longer practical. I want to convert to just having the place put in hay, which will be cut by others with the right equipment. To make that happen I have a fellow coming in with with a dozer to make to place mower friendly. Once that is finished I will need a tractor to maintain about a mile of dirt and gravel roads, do clean up work, and bush hog areas that are not suitable for hay. I'll most likely put in a couple of food plots for the critters, maybe 5 acres total.
I've been looking at used tractors that have a wide stance, like Ford models 3910 and 3930, or the Deer 5000 series. I figure I need at least 40 hp. 4wd, a loader, ag tires loaded, and as wide a track as possable ( I have a low pucker factor ).
My budget is $15k. Any other tractors you folks think I should look at?
Thanks.
   / Mowing the hills. #2
My place is very hilly with about 60 acres of woods and the rest in old hay fields. I learned a long time ago to "hog" up and down the hills and not sideways. It makes life a lot easier.
The attached is one of the hills I mow, you can get an idea of the pucker factor if I didn't mow up and down
   / Mowing the hills. #3
Toad,
Beautiful property, and I agree, if at all possible mow up and down any hill.
   / Mowing the hills. #4
Depending upon your needs, you might look at Power Trak (they have a forum on this site). Can slope mow or bush hog crosswise on a 45ー slope if you get the PT 1850 like i have. Not the best tractor for the food plots though if you are plowing them a lot. Fine for maintaining the road. Can use the bucket on side slopes too.
Nice tractor for some people (great for my needs), bad for others.
Ken
   / Mowing the hills. #5
If you can find one in your area look for a Massey Ferguson 400 or 500 series Low profile. The low profile model is great on the hills for mowing.
   / Mowing the hills. #6
I have a fairly hilly property as well. I came up with 3 choices. Massey 300 or 400, Power-Trac, or buy a TYM and put dualies on it.
I could not find a Massey. No local dealers and if there were any no wide stance tractors. Also the price was a bit steep. The Dualies and the TYM was a decision based on that I felt it was a really good tractor a great price, and if I messed it up by putting dualies on it I would not cry nearly as hard as if I had broken a Deer.
I was about 10 seconds away from buying the TYM when I was given the chance to buy a used Power-Trac 1850. It came it at round the same price as the new TYM.
The PT line is a great, simple tractor. Used or new, they have the same level of reliability. Depending on your slopes I would put this on your consider list.
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
UNUSED MOWERKING QUICK ATTACH BRUSH CUTTER (A51244)
UNUSED MOWERKING...
2009 MIE Vessel and 2017 LORT Trl (A50324)
2009 MIE Vessel...
2004 Ford F250 (A50515)
2004 Ford F250...
1994 PETERBILT 379 SLEEPER (A50046)
1994 PETERBILT 379...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
