Mower Size Recommendation on XG3135H
   / Mower Size Recommendation on XG3135H #1
rexvaughn
Lowell
LS XG3135H
I am purchasing a new XG3135H and getting some new implements. I am wanting to get a rear bush mower and box blade. To get coverage over the tires it looks like it will take a 6 foot mower but I'm concerned it will be too much for the PTO power. Anyone have any personal experience with this setup?
   / Mower Size Recommendation on XG3135H #2
I have an XG3037 and decided to go with a 5' mower and blockade. Most folks, including implement dealers, recommended limiting my heavy duty implements to the 5' range for my size tractor. Works well for me.
   / Mower Size Recommendation on XG3135H #3
30 PTO hp is enough to run a 6' mower as long as your not expecting to mow 5 ft tall grass/weeds.
   / Mower Size Recommendation on XG3135H #4
The 3135s have 28HP at the PTO. While that's not quite enough to meet the "widely accepted" requirement of 5HP/ft, you'd probably do fine with a 6' mower ... so long as you're not trying to cut really dense grass or large sapplings.
I went with a less expensive 5' mower, as I only have 2-1/2 acres of pasture to mow.
   / Mower Size Recommendation on XG3135H #5
I have the 5' Bush Hog razorback on my XG3135H. It comes within about 3" of the edge of the tires. It's not a big deal unless you are trying to get really close to buildings or fences.
   / Mower Size Recommendation on XG3135H #6
5ft. I wouldn't take a chance on not enough PTO hp. vs gaining 12" more cutting width. You may have warranty issues if something should break.
   / Mower Size Recommendation on XG3135H #7
My manual has a page on recommend max width on implements listed by type. Using that as a guide should keep you in warranty.
   / Mower Size Recommendation on XG3135H #8
Looking at a 3135H as a possible replacement for my 1720. What does the manual say about the mower size? I have a 6 ft king kutter I use with my Ford. How do you like your 3135?? Any problems with pto power?
Thanks!
   / Mower Size Recommendation on XG3135H #9
I have a boomer 24 (new holland). It delivers what 18 pto hp. I pull a 5 foot hog just fine. The "conventional wisdom" says I should go. 4 ft. Well if the weeds are too tall I just slow down or take a 3/4 bite. So if I was constantly going to max the mower out it might be an issue.
   / Mower Size Recommendation on XG3135H #10
I have the older 3000 series XR3037HC. All 3 pt attachments I have are 6' with the exception of my snowblower which is 7'. 6' attachments will work fine on your XG3135. If buying used attachments I have found used 5' attachments more readily available.
UNUSED 120 Pairs Safety Work Gloves (A50860)
UNUSED 120 Pairs...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
2012 Ford F-250 XL 4WD Flatbed Pickup Truck (A50860)
2012 Ford F-250 XL...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A51039)
Toyota 6FGU25...
2020 Case IH Farmall 130A Tractor (A50860)
2020 Case IH...
