Mower bolt problem
   / Mower bolt problem #11
In another thread I talked about my blade style problem but I encountered another one when I put new blades on yesterday.
It is a 60 deck on a BX2350. One blade bolt was badly damaged when I swapped blades. It came out really hard. Probably took 3 minutes with an impact. About just the last half inch of threads were badly tore up, almost looking worn down. I got a new blade bolt and ran a tap up in the hole. It did a lot of cutting, which I expected. The last part of it cut really hard, which is probably where the damaged part of the bolt was. It then seemed to tighten up fine.
Questions? What caused it? I don not think the bolt was loose before I took the blade off but I am not positive. I install the bolts by hand almost all the way to engage the hex washer, then tighten with an impact.
Should I expect problems again? Can you replace just the shaft or would I need an entire spindle assembly?
Don't use an impact gun to tighten the blades, invest in a torque wrench and use the proper torque. I ruined a spindle on my Landpride 72 inch by using an impact gun. No more. Of course use anti-seize like the others recommended also. The finer the thread pitch the easier it is to damage the threads, I'm guessing the thread is metric and if I know the Japs I'd say 1.25mm pitch which is easy to damage.
Good luck, Fred
   / Mower bolt problem #13
A friend was just showing me his thread chaser sets. He says NOT to use taps or Dies to repair damaged threads as you just make a mess of it. Just sayin! I would use a tap or die, as I don't have that luxury or if it was an expensive thing, take it to him!
I have a torque wrench. To be honest it is awkward to use so I am just being lazy. When I take the deck off it would be easy but normally I lift the front end up with the end loader to sharpen blades and there is not a lot of room to work.
7ft Double Legs Lifting Chain Sling (A57454)
7ft Double Legs...
2262 (A58376)
2262 (A58376)
2014 PETERBILT 579 (A58214)
2014 PETERBILT 579...
2204 (A58376)
2204 (A58376)
2023 FORD F-250 (A58214)
2023 FORD F-250...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
