Moving large rounds with winch?
   / Moving large rounds with winch? #21
The use of winch and even a lot of sheave blocks for the cable will be
less work for you as your wire rope will haul faster and smoother
with the sheave blocks and will not become stuck.
The other issue is control- if you have the sheave blocks in place the
chain used to attach the sled will only go as far as the sheave and then you
can unhook the sheave block to let it pass to the next one until the load is
where you want to set it.
About the terrain:
Is it possible to simply have a straight shot from the dumping point
to the area where the rounds ahve been cut up?
The thing is the winch will not be at all concerned with the grade up or down.
If you have a nearly straight route you can simply lift the empty sled and
lower the loaded on slowly with extra cable and connectors simply using the
single lay of wire rope for the tow rope if needed or purchase more wire rope to lay in the winch spool as the tension created by the load will keep the cable tight when lowering the loaded sled with rounds, as long as you have one round left in the sled it will provide enough loading to keep the cable taunt when pulling the sled back up to the clearing where you are working.
A small diameter wire rope and a sheave block line will also work well in a straight ascent if desired as the wire will always be under tension pulling slowly up or down for you.
It is also entirely possible to set up a single tow rope with two smaller ATV winches using the sled/hood as the middle point with a second person operating the brake of the uphill winch attached to a nearby tree with a tree saver loop band if the tree is valuable to protect it.
You could build a 36-48 inch wide stone boat of sorts 8 feet long using landscape timbers and galvanised building straps used for lumber joining and making the ends out of 6 by 6 lumber to hold the rounds and have a point of attachment for the webbing straps to secure them on the sides of the end timbers.
You will want to use threaded rod to splice the landscape timbers together and the same for the 6 by ends to attach the timbers and use the ends of the threaded rod to attach the the tow chains to carry the rounds down to the clearing and chain or strap them in place for the trip down hill in either case using the sheave blocks and extra cable as well.
The end of the chain will be slid over the rod and it will be secured with washers on the inside to prevent the wood from being weakened and damaged by the pulling force.
A nylock nut and washers would be used on the outside end to secure the chain link in place while towing the sled
   / Moving large rounds with winch? #22
You can't cut some stumps closer to the ground and shove your rounds downhill and split them there??:D
Thanks for all your help Leonz.
Egon, the tree is actually "in line" with my parents sun room. If I were to push the rounds (probably impossible to move them by hand) in the straightest line I'd be playing russian roulette with my parent's house. Not sure they'd be too crazy about a round taking a chunk of their house away. And if I pushed them at an angle they'd be pinballing off of the trees you see and might possibly end up in my neighbor's yard - no good.
I might try the winch / sheave block set up the Leonz mentioned. There are some other trees way in the back of my parent's property that are suitable for firewood and a small winch set up would help me get them out without destroying the other trees.
I'll let everyone know how I make out - hopefully with pics.
   / Moving large rounds with winch? #24
Sounds like you've got your hands full Connor - got your email, but get rejected when I try to respond. Don't try to get back there til later this week after the ground refreezes. Call me @ 508-272-7739 & will help with the repair & advice.
Dave
   / Moving large rounds with winch? #25
We moved a good truckload of split white oak out of the woods pretty quickly on Christmas Eve. Not near as big as what you have, but once split it's all the same, right? We split ours by hand, so getting a splitter to the wood was not an issue.
We set up a "bucket brigade" line with my brother, my daughter, and my two nieces. The farthest wood was probably 30 feet away from the truck, so we were 5-6 feet apart tossing the wood. We rotated the person who had to pick up the wood off of the ground as that is the hardest part.
If you can get your splitter to the logs (maybe winch it there?) and get it split in place, then you can set up a line and toss it to where you can position your trailer. To move your wood 50 feet you'll need more people. I'd estimate about two cases of beer would be sufficient for the task.
   / Moving large rounds with winch? #27
Here's a short video of our log tossing line. It's a little shaky but Mom was running the camera and it was cold out there, and at 89 she shakes a bit even when it's warm!
Logline.mp4 video
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A48082)
2019 Club Car...
Morooka MST 660VD Tracked Dump Truck (A51039)
Morooka MST 660VD...
Trailer Axles (A50860)
71066 (A49346)
71066 (A49346)
Landscape Wagon (A50860)
Landscape Wagon...
2019 Generac MLTS-1 2.4kW Towable Light Tower (A49461)
2019 Generac...
