schmism
Super Member
I've been around the block a time or two. I've mounted my fair share of troublesome tires. Wheelbarrows, yard carts, lawmowers you name it. However I have never had to mount one of the large rear R4 titans on my class 2 CUT. This past week was my first (unpleasant) experience having to go through this.
I have a leaky front tire (bad valve stem) and that I have to air up every day or so but rarely does it loose the bead so its as easy as just throwing the air chuck on it.
The rear tire however lost its bead and was showing a gnarly gap.
So off comes the tire, I round up a ratchet strap and get to work. Oh boy was I in for a treat. An hour later I was no closer to a sealed bead than when I started. I did all the tricks. Straps, beating on it with a sledge, getting the large flow rate air line out, nothing was working.
So Ill fall back to the tried and true method of spray some flammable liquid in it and hit it with the propane torch. This is not a method I like to use, its my last resort method, have used it a half a dozen times over the years, mostly seating large 35" and larger off road tires back on rims on the side of the trail, never before on a Titan branded tractor tire.
The flammable stuff in a can that I remember being great 10-15 years ago.... I guess brake clean isn't what it used to be. and the carb cleaner is seems worse, as if i just sprayed kerosene in the tire, some sort of a nice warm cracking fire in my tire not the WHOOOMMMMPPPPP that i need!
So yeh, it takes like 5 tries, 3 different versions of spay solvent before I find one that will ignite like i need.
Its mounted but man, talk about a fight.
What are you guys using these days that have to do this more often?
