More Hydraulic Questions
   / More Hydraulic Questions #1
joe swanson
Bronze Member
Adirondack Mts, Fulton County , NY
YM 336D
I have a 336D with a FEL and YM765 Back hoe. The Hoe is powered by a PTO pump. While the FEL loader uses the tractor Hydraulics. Why can't I use the tractor Hydraulics to power the BH in the same manner it is used to supply hydraulic power for the FEL loader.
Seems like a couple of T fittings and a few quick connect for the BH would allow the same supply and return to be used for the BH??
What am I missing.
Joe
   / More Hydraulic Questions #2
You can use the tractor hydraulics to run the backhoe. It may not be quite as fast. You do not want to use Tees. This will create a parrallel circuit . The oil will go to the circuit of least resistance. You need to plumb the backhoe in series with the loader & always make sure you hook the hose together when you remove the backhoe, so you don't wreck the tractor hydraulic pump.
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
2016 Ford Escape AWD SUV (A48082)
2016 Ford Escape...
POWER BNG2800IE INVERTER GENERATOR (A50854)
POWER BNG2800IE...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
miller light cooler (A50860)
miller light...
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
