Minimum pto shaft engagement
   / Minimum pto shaft engagement #11
Even the overrunning clutch doesn't matter though, if splined on both ends, clutch will work on either end...
I know from experience that 2" of engagement isn't enough :), my 5' finish mower shaft had been shortened before I got it and only had about 2" of engagement and it came apart while mowing, didn't do any damage to anything other than stalling the tractor. I put an overrun clutch on it and is good to go (my tractor doesn't have one in the PTO output so was NEEDED anyway, not for the finish mower but for the brush hog...)
   / Minimum pto shaft engagement #12
ORC’s only work on the tractor end, they will not transmit power if installed on an implement.
   / Minimum pto shaft engagement #13
I think you're right, I thought I had figured it out that they could be either way, but I just went out and looked at the clutch and was wrong... don't feel like spending the time to look deeper into it right now :)
It's better to have it on the tractor end anyway, I imagine the PTO output shaft is better supported than most PTO input shafts on implements...
   / Minimum pto shaft engagement #14
I would get the correct length shaft and not have extra links cobbled together that can break
   / Minimum pto shaft engagement #15
You don't need to spend much time. It is called overrunning or one way because it only transmits power turning one direction. If you turned it around and put it on the gearbox, it would rotate the other direction and the gearbox would not turn.
PALLET OF MISC PARTS & SUPPLIES (A58374)
PALLET OF MISC...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
1608 (A57192)
1608 (A57192)
2022 DODGE RAM 2500 SERVICE TRUCK (A58214)
2022 DODGE RAM...
Sellick 560 Forklift (A57148)
Sellick 560...
