Winches Milemarker hydraulic winch
   / Milemarker hydraulic winch #21
Despite all of the negative comments (which I don't discount completely) I think this is an ingenious solution and maybe with some modifications it can be safe.
Well, I have given it some thought, since a winch and a PHD are really the only two tools remaining on my "wish list" now that I have forks and a stump grinder. Yet, I point out one example of using a type of ground anchor, much smaller than a PT's HD rock bucket, and the whole thread "turned left at Albuquerque"...
A 422/425 isn't heavy enough, with enough ground pressure, to be a good anchor itself. Similarly, a 2,000/3,000 lb winch would only be helpful in getting the PT unstuck -- which wasn't my intended use...
I have too many potential uses where a tree might not be available, or if it is, it would be best used to anchor a pulley/snatch block, and some other method of anchoring the winch is essential. We had to wait and use a little Komatsu dozer to retrieve one log we cut when it went downhill on us -- my brothers 65HP Massey 4WD would only sit and dig holes... and we were pulling it uphill, into a clearing, away from any trees...
   / Milemarker hydraulic winch #22
I have a 2000 lb electric winch and I agree it is not very powerful. I find I rarely use it. I usually use a boat winch when I am stuck and it works very well. It is on a 2 inch receiver post and I plug it into the 2 inch receiver on the back of my PT. I have found that if I connect the strap up high on a tree (5 feet) it is easier to get out. Pulling straight back does not work when I am really stuck. I am rarely barely stuck since you can usually pull/push yourself out with an attachment.
   / Milemarker hydraulic winch #23
For those wanting a hydraulic winch, there are two good buys on ebay right now.
search for 12,000 lb mile marker hydraulic winch currently $400 and it is new
search for Hydraulic 8000lb Toe Truck Winch(used,spool full currently $250 but has a buy it now of $395 which seems like a good price to me
Ken
   / Milemarker hydraulic winch #25
that's what the portable gas winch is, a capstan winch. Just not using the tractor engine but a small Honda instead.
Ken
   / Milemarker hydraulic winch #26
... We had to wait and use a little Komatsu dozer to retrieve one log we cut when it went downhill on us -- my brothers 65HP Massey 4WD would only sit and dig holes... and we were pulling it uphill, into a clearing, away from any trees...
In a situation like that, my father would take out his chain saw, cut a seat into the log and tell us that was a good place for a bench to sit on! :) (we didn't have a winch ;) ).
Pulleys are your friend if you do not have a heavy enough anchor and/or a strong enough winch.
Thanks for the tractor install pics, seeing the cushion/reducer valve mounted helped me figure that out in my head.
Well, there seems to be some thought that a 9,000lb mile marker is a bit big for a 422/425, luckily for those of you serious about a hard working (non-electric) winch. Mile Marker makes a 5,400 lb one, though they are a bit hard to find. I think it's a manual valve unit, two speed and runs about $560 with steel cable. The guys at the below link would have details. I think I bought both my Mile Markers (one went away with a vehicle I totaled and the other is sitting in the shop) from them and was happy with the service.
Winches Plus
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2014 MACK CHU613 FRAME (INOPERABLE) (A58214)
2014 MACK CHU613...
2210 (A58376)
2210 (A58376)
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
Terms & Conditions of (Buying through EquipmentDealz Auction) (A59213)
Terms & Conditions...
2013 John Deere 624K (A55272)
2013 John Deere...
