Michigan 125 - no drive from front diff
   / Michigan 125 - no drive from front diff #1
geobar
Trying to save unnecessary work, I am looking for advice to diagnose why the front wheels do not drive my Michigan 125ADC Series II. The rear wheels move the machine when in 4wd, but in 2wd the input shaft to the front diff is turning but the wheels do not. One day after parking the machine with the bucket accidently set too low, I stepped on the right front wheel while getting down. Unexpectedly, it turned remarkably easily. It made me wonder if the problem could be local in that wheel, perhaps with the planetary gears within the wheel assembly. The wheel assembly has two caps that can be removed -- a small one (maybe 9 inches) with the oil fill plug, and a large one (maybe 18 inches) covering the whole assembly. Should I just remove them and see what is under there? Or can someone suggest a better way to figure out the problem? Can anyone recommend a source for parts for this 40 year old machine? Thanks
   / Michigan 125 - no drive from front diff #2
Pull the two small ones off and check the axles first the other thing is most older loaders like that did not have no-spin in the front so one wheel will turn and not the other
Thank you for the reply Dirthog. If I understand you correctly, when I pull off the smaller cap I will see the axle. Thus if the wheel spins but not the axle then the problem is with the planetary gears there. By the way, I should have included in the initial post that when I turned the right front wheel neither the other wheel or the drive shaft to the diff turned. If the system was good either the other wheel should have turned a corresponding amount or the drive shaft spin considerably. Right?
2009 Chevrolet Malibu Sedan (A51694)
2009 Chevrolet...
2007 Anderson 25ft T/A Flatbed Equipment Trailer (A51692)
2007 Anderson 25ft...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
2008 Caterpillar 45kW C4.4 3-Phase T/A Towable Diesel Generator (A51691)
2008 Caterpillar...
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A53843)
2017 FORD F250...
2014 Nissan Versa Note Hatchback (A51694)
2014 Nissan Versa...
