Mfwd
   / Mfwd #1
hfasteve
New holland tc30
The four wheel drive is not working on my TC30. I have a lot of employees who use it so I don't really know if anything happened. Any ideas on where to start looking to fix it?
   / Mfwd #2
How does the lever feel when you try to engage 4wd? Is it the same or different than when it did work? Sometimes it is very difficult to engage and disengage , underload or on uneven ground, Maybe something broke on the linkage?
   / Mfwd
Thanks for the warm welcome.
The lever feels the same when I move it. It isn't difficult or anything. The linkage is all enclosed, right? So I will have to drain all the fluid from the gear box to check it out.
   / Mfwd #6
Welcome to TBN!
If this is a TC30S not D, then the fact it is not difficult :) is a clue that your linkage may have something wrong with it.
Dave.
   / Mfwd
What is the difference between the tc30s and tc30d? Thanks for replying!
   / Mfwd #8
S models don't have hydrostatic transmissions. The S stands for shuttle or standard I guess. I am not familiar with the mwfd models.
My tc40s goes in and out of 4wd okay, but it would be unusual to have little resistance or not have to reverse the tractor for 2-3 feet on level ground to get it disengaged out of 4wd.
Dave.
   / Mfwd #9
From looking at the parts diagrams on messicks.com, the TC30 has a FWD system that is not at all like our class III Boomers (TC35/TC40/TC45). The TC30 has a shifter fork inside the front transmission case and a shift lever on the left side of the front transmission case. My guess is the lever is just to the left of the operator's seat where it can be easily reached with the left hand. I would make sure that the rollpin in the base of the lever was intact and that the shaft going into the transmission is rotating when the lever is moved. If there was resistance and the operator forced the lever, it could have sheared off the rollpin or bent/broke the lever. It's not very likely, but possible.
Next, you need to find out if the problem is with the shifter or maybe with the front differential and driveline. With the engine off, if you put the tractor in gear and into FWD and then jack up only one front wheel, you should not be able to turn the wheel that is in the air. The single wheel in the air should turn only if the tractor is NOT in FWD. If the wheel turns, it means FWD is not engaged or there is a problem with the driveline. There is a rubber boot with clamps on the back of the front differential. I would loosen the clamps and try to pull that boot back so I could see the driveline while turning the wheel. Obviously, this is a job for two or more people. If the driveline is turning when you turn the single wheel in the air, then the problem is in the transmission shifter. If the wheel will turn and the driveline does not turn, then the problem is in the front differential.
   / Mfwd #10
Reminder-never depend on just a jack to hold up a car, truck, tractor whatever if you intend to put anything you value under it. The neighbor across the street died when his car fell off the jack.
2005 FONTAINE 48 FOOT FLATBED (A53843)
2005 FONTAINE 48...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A53473)
2012 KINZE FLAT...
2011 Wacker Neuson RD12A, 36" Double Drum Roller (A52384)
2011 Wacker Neuson...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A51246)
JOHN DEERE 437E...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A51694)
2014 Glasstream...
2008 International 4300 18ft Landscape Dump Truck (A51691)
2008 International...
