Measuring Power Consumption Of 230VAC circuit?
   / Measuring Power Consumption Of 230VAC circuit? #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
P3 International P446 Kill A Watt EZ Electricity Usage Monitor - - Amazon.com
I've used this device for measuring kilowatts consumed on 120 VAC circuits and wondering how it could be used to measure the consumption in one leg of a 230 VAC circuit.
I had a one ton mini-split heat pump/AC installed recently for a sunroom addition to our home and would like to get an idea how much power it is using.
Wondering, first of all, if measuring the power used in one leg would give an accurate indication of total power if taken times two.
Then wondering how the kill-a-watt device (see above) could be temporarily wired at the breaker panel assuming it would be in series with one leg of the 230 VAC but not sure how it would simulate the neutral of a 120 VAC circuit.
Hope that makes sense and would like to hear your thoughts. I'm not an electrician but have done a lot of my own wiring over the years using advice from electricians.
   / Measuring Power Consumption Of 230VAC circuit? #2
is there a reason you don't want to use something like this?
Digital Clamp Meter Meterk 6 Counts TRUE RMS NCV AC/DC Voltage Auto Range AC Current Clamp Multimeter Capacitance Resistance Frequency Temperature Measure (Black Digital Clamp Meter) - - Amazon.com
   / Measuring Power Consumption Of 230VAC circuit? #4
The clamp-on will tell you the current draw at the time, and you could roughly calculate the power usage at the that instant. To get an idea of the power consumption would require knowing how long the equipment runs each day / week / whatever.
The Kill A Watt appears to function as a usage meter, giving the power consumption over a period of time.
   / Measuring Power Consumption Of 230VAC circuit? #5
Do you really want to know how much power it uses, or how much energy it uses?
That is how much power it uses when it is on; or how much energy it uses over the course of several days (taking into account that it cycles off and on)?
Power is an instantaneous (immediate) measurement. Energy is over time. Comparing power to energy is like comparing your speed to distance traveled.
A watt meter (or current meter and some math) will tell you the power draw.
A watt-hour meter (Joule meter really...semantics) will tell you the energy consumed.
And remember that Kilo just means 1000 of something.
You could manually figure energy if you know the power consumption and the running time duration.
As other noted, the Kill A Watt Meter really measures kilowatt hours (energy). Plus it plugs into a 115v outlet.
   / Measuring Power Consumption Of 230VAC circuit? #6
Power is energy per unit time, not intantaneous.
One Watt = one joule PER SECOND.
I had searched for a 230 volt version of the energy meter to no avail, so thanks for the link guys. That is exactly what I need to measure energy consumption over a period of days or even weeks. Just want to know what it costs to heat this sunroom in Kansas in the middle of January at a given thermostat setting for example. Next summer, when its a hundred degrees in the shade, how much to keep at 70 degrees?
Digital Clamp Meter AP-57C-APP Bluetooth Clamp Multimeter 4 Counts Auto-Ranging Multimeter with DC/AC Voltage & Current, Resistance, Temperature, Frequency, Duty Cycle - - Amazon.com
I have been using one of these to record the amps as I was having an issue with the mini split unit short cycling. What I found is that the internal temp sensor of the air handler (inside unit) was picking up heated air causing it to shut down the compressor. The unit would cycle off for a couple minutes and then back on for maybe ten or so minutes.
Using the "follow me" setting on the remote controller overcomes this problem by using the sensor in the remote to control the unit. The remote can be placed out of the direct path of the air handlers output thus stopping the short cycling.
The phone app used with the above clamp meter allows taking and recording the current as many as 120 times/minute or down to as few as once/minute. It also records minimum and maximum current draw and at what time each occurred. Works good for recording high current draws on 12 VDC also.
https://www.amazon.com/dp/B01MRZAFA...9Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
Found this unit which has the advantage of resetting capability for Kw. It does bring up the question, in my mind at least, can the amperage measured in one leg of 230VAC be used to directly calculate wattage (volts times amps) or does it need to be factored by two since there are two legs at the given amperage.
I understand that the amperage required to run a given device on 230VAC would be half of what is required to run it on 120VAC but the energy calculation is not clear to me given the two legs of the 230VAC.
More info coming soon! (A46684)
More info coming...
DIESEL PANASONIC CF-31 LAPTOP (A48992)
DIESEL PANASONIC...
2017 Ford Fusion Sedan (A46684)
2017 Ford Fusion...
1998 Dorsey Trailer, VIN # 1DTP16K29WG052604 (A48836)
1998 Dorsey...
2014 Ford Transit Connect Cargo Van (A46683)
2014 Ford Transit...
Holland Transplanter (A49251)
Holland...
