Measuring fuel additives
   / Measuring fuel additives #1
Bob_Young
Veteran Member
North of the Fingerlakes - NY
Ford 4000; Ford 2000(both 3cyl.);JD40; 2004 Kubota L4300; 2006 Kubota B7610; new 2007 Kubota MX5000
Hi all,
I'm looking for a plastic measuring container/bottle graduated in ounces that can be used for measuring out diesel fuel additive and 2-cycle oil. It would help if the graduations were clearly legible (so the reading glasses aren't always needed) and go down as low as one ounce.
I had one that was perfect except it was glass. Knew I'd eventually break it and I did. Now I'm using a plastic measuring cup from the grocery store; it's far from ideal....and I suspect not meant for petroleum products either.
Saw someone here proclaiming their satisfaction with a measuring bottle whose name began with an 'N'. Did the search with the spelling I remember and came up dry. Local autoparts store couldn't help either. If anyone has a link, please pass it along and I'll order a few.
BTW, 3 oz. of TCW-3 2-cycle oil per 5 gal. of fuel has all my diesels purring. If anyone knows of a negative to this, please holler.
Bob
   / Measuring fuel additives #2
I just use one of the wife's old 1/4 measuring cups it equals 4 oz. I use 4 oz of Power service to 5 gal of fuel so this is all I need.
You may want to look for a small Pyrex measuring cup, they stand up to a lot of abuse.
   / Measuring fuel additives #3
Bob_Young said:
Hi all,
Bob
Anywhere that sells photo darkroom supplys. Hard "plastic" but almost totally unbreakable..and chemicals wont destroy them
   / Measuring fuel additives #4
A stainless steel measuring cup works fine. This one is 2 oz (1/4 cup).
   / Measuring fuel additives #5
The Ratio Rite is used by thousands of 2 stroke dirt bike guys...
RATIO-RITE MEASURING CUP
I'd get the optional lid too...
BTW know nothing about the company linked above...lots of places sell them. They measure in ounces and cc's....
   / Measuring fuel additives #6
Same here,I just used one of the wifes 1 million measuring cups she has on hand from the kitchen,heck she never missed it LOL.coobie
   / Measuring fuel additives #7
I measured how much Power Service I put in a 5 gallon container 5 years ago. Got a mental picture of how it looked coming out of the bottle and how it looked in the container. Have not measured since. It's not like you're going to hurt anything if you add too much.
   / Measuring fuel additives #8
Yeah, I use the "glug-glug" method myself for adding Power Service. Much easier then using ameasuring cup, but not as accurate, of course.
For 2 stroke mix, I use the wife's measuring cup stuff. I mix a quart of fuel at a time for my chainsaws.
   / Measuring fuel additives #9
Most auto parts stores also sell measuring funnels. They have a shut off valve incorporated into the bottom of them with about a foot long tube. Makes pouring into a fuel tank very easy. Just stick the tube in the fill neck, make sure the valve is off, fill the clear funnel with the proper amount of additive and then open the valve. I have also seen these that have large caps that go on the top of the funnel to keep dirt out.
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
1043 (A50459)
1043 (A50459)
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2014 FREIGHTLINER...
2012 Geringhoff NS1200 Corn Head (A50657)
2012 Geringhoff...
SOLDERING IRONS, GLOVES, AND STANDS (A50854)
SOLDERING IRONS...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2016 FREIGHTLINER...
