Mccormick cx85 question
   / Mccormick cx85 question #1
Andrew west
Western australia
Mccormick
Hi everyone. I have a mccormick cx85 tractor which will only start intermittently....
Can run and switch of then won't start again. Then next day will start perfectly????
Have checked everything I can. Fuses and loose connections etc.
Maybe it's the computer? It's a very electric tractor!! Does anyone out there have one who maybe has had this problem?. I have treated this like a baby since new, and not a good buy!. Lots of problems. Don't buy one is my advice.
   / Mccormick cx85 question #2
When you say that it won't start, do you mean that the starter won't turn it over or that it cranks but doesn't start?
   / Mccormick cx85 question #3
if you mean it won't turn over with the starter, check you safety switches and make sure you have a good ground connection for the battery
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
90018 (A48082)
90018 (A48082)
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
Unused Delta Crash...
196046 (A50459)
196046 (A50459)
