Comparison Massey or Kubota
   / Massey or Kubota #21
I feel like I'm being psychoanalysed! - MF dealer is 15 mins away, Kubota 45 mins -
MF has proved (& Kubota seems) competent & reliable, with a country service attitude, so no dramas there.
The 148 was always good, apart from no power steering, & the brakes - apparently normal for the model (dry)
& proved hazardous when pulling 400 L of spray up a hill - brakes would only just hold
if you stamped hard enough to drain all the blood from your right leg. had to jackknife a trailer load of round bales
on a hill when the load was too great for the little girl & she started rolling backward.
Looking to replace with similar HP (& wet brakes) as I don't wish to be underpowered nor overpriced.
Features aren't a consideration unless they make attaching implements easier, so bells & whistles are unnecessary.
Yes, something new as I'm 66 & would like a new one that will see me out without major mechanical problems -
understanding that my reliability is likely to be dropping off faster than the tractor's.
If TSO's MF suggestion is too expensive, do you have a Kioti or LS dealer in your neck of the woods?
South Koreans make good tractors as well.
   / Massey or Kubota
have seen Kioti in farming magazines, but unaware of anyone within cooee -
never heard of LS until I started researching here - must be a US only seller?
In any case there's a problem in getting parts for most of the other brands.
   / Massey or Kubota #23
I am really liking what I have read on the Massey tractors but its hard, to hard for me to go with the India tractor over the Japanese made Kubota. It sounds like you want to keep this tractor for many years so I would have to go Kubota.
   / Massey or Kubota #24
What problem getting parts ???
News to me..
   / Massey or Kubota #25
   / Massey or Kubota #26
Or the US for that matter. There are recent posts on trying to find float valves for CK series. Apparently they used to exist as there are pics of an install of one, but they maybe dried up?
   / Massey or Kubota #27
Oth... it looks like the Massey 2615 is your modern day equivalent to the 148. I'm not sure if you have the 8x2 standard trans, or the 12x4 Multi-power... but the 2615 comes with an 8x8 synchro shuttle. You'll clutch from F-to-R, but the speed changes within a range will be clutchless.
With that said, I have read different things on the 26xx series. I've read that there are/were actually 2 build locations. The 26xx series are/were made in India, and the HD26xx series are/were made in Brazil. Some of the reading suggested that the Brazil builds were better, other reading suggested that the Brazil builds were stopped for quality control issues. The reading also suggested that most or all of the problems related to the 26xx tractors were sorted out. The problems seemed to pertain to leaks/seals. But more recent posts suggest the 2600's are good, basic, utility tractors. It appears that the engines in the 26xx tractors are made by "Simpson" ... who appears to be an Indian company that builds "Perkins" engines under contract. So, essentially, the engine appears to be an Indian built Perkins.
Bottom line regarding the 26xx tractors --- if you're comfortable with that size, and you have a good MF dealer (in case any warranty issues come up) then I wouldn't have any problem going with the 26xx (though I'd go with the 2615 to have the same power as your 148).
I think that the MX5100 is also a nice tractor, and it will probably be a bit more nimble than the 26xx or your 148, because it's a smaller tractor. It will also have a friendlier transmission.
But again, it's a smaller tractor. If you're considering the MX5100, then see if your MF dealer has any Massey 1500's, 1600's, or 1700's. 1500's were replaced by 1600's, and 1700's replaced the 1600's. My Massey 1648 specs almost identically to your 148 in weight, power, etc. It is about 6" shorter in wheelbase, so it will be more nimble. It will be MUCH more comfortable than your 148 or the 26xx, as it is more of a premium tractor. It comes in 4 transmission options: 8x8 synchro shuttle, 12x12 Powershuttle (if you're not familiar, you can change F-to-R with a clutchless lever on the column, as well as synchronized clutchless speed changes), a 12x12 DynaQps Powershuttle (same as 12x12, but it offers push-button speed changes), and finally, Hydrostatic (which I have). To be honest, the Hydrostatic might be worth a try for you, since your are using this tractor as a "travel" machine to do chores, and not a "ground-engaging" machine to plow. The Hydrostatic has built in braking when you return the pedals to "neutral" while in gear. Meaning, the drivetrain only moves when you move it, or when you put it into neutral. Anyhow, the 1600's are numbered 1648, 1652, 1655, 1660. The 1660 has 59hp and has the DynaQps Power-shuttle. It's a darn nice tractor. I can't have it because I need Hydrostatic for my uses (landscape company). But that's the tractor I'd have if I could have a more "standard" transmission. (here is a good video explaining the different trans options: https://www.youtube.com/watch?v=JyKt6oXlFHU )
Anyhow, these tractors are Iseki built in Japan, and are bullet-proof. They are badged as either an AGCO tractor, Massey Ferguson, Challenger (Cat), or Iseki. I believe you have Iseki in your market? They are blue there I think. If you find an Iseki TG5470, that is actually a MF 1547. Same as my tractor, but the previous generation (same drivetrain though, only changes were a slightly adjusted operators area and plastics).
From my personal experience, Iseki-made-MF's offer better reliability than Kubota machines.
   / Massey or Kubota #28
You mean the remote valve with the float feature that many didn't think/know even existed.
Rear remotes without the float feature are no problem getting.
   / Massey or Kubota #29
I'm upgrading my MX5100 as we speak, basically. It is a very nice tractor and come with a piece of property I purchased a couple of years ago. Has more power than it has weight, so I little light for what I was doing with it, but it did get the job done. 2wd by the way.
However, wanted to comment to what two dealers told me when I was discussing my upgrade with them, take it for what it is worth.
1) Dealer salesman, actually a friend of mine, said MF owners get their feelings on value hurt when they want to look at trading. Honestly though, he would probably say this on anything not green.
2) I felt the Kubota salesman gave a more honesty response. After demoing both the deere and Kubota, told him I was going to look at the New Holland T4.75. He set there a minute (in person) and said, yeah, I can see that they make a good tractor...don't buy the MF however, we'll give top dollar on deere, Kubota, and New Holland, but MFs just don't get it. I did not bring MF into the conversation, just the New Holland dealer sells them as well and the Kubota dealer knew it.
That being said, I did sit in an MF, about the same size as the T4.75 but not sure of the model number. First thoughts was how well placed the control levers where and that I really liked. Loader frame looked weaker, but never looked at spec's. Didn't like the additional "bump out" of the rear of the cab. However, as I said, didn't do any research on them or even price it at that time.
   / Massey or Kubota #30
Interesting, I would have put MF in the same class as NH. Both are made by a 3rd party and lesser known. His comments on Deere and Kubota are what I expected, often you get back what you paid.
Toro Z-Master 5000 Series 72in Zero-Turn Commercial Mower (A56857)
Toro Z-Master 5000...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2014 Ford Escape SE (A56859)
2014 Ford Escape...
2005 John Deere 200C LC (A55272)
2005 John Deere...
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
2014 DITCH WITCH RT45 (INOPERABLE) (A58214)
2014 DITCH WITCH...
