Massey Ferguson 1540 Linkage
   / Massey Ferguson 1540 Linkage #11
The only issue that I’m aware of is an intermittent hydraulic pump chatter and resulting loader chatter on certain models during the series. I never bought mine back for evaluation, as it was just out of warranty when I bought it. It does it every once in a while. I’m not sure if it involves a complete pump change or not. There’s a split in serial numbers where the suction components were changed, like the hydraulic filter and hose. I’ve put in the second series.
Otherwise it’s a pretty bulletproof machine
good to note, thanks. No issues with my one just yet, very happy with it
   / Massey Ferguson 1540 Linkage #13
As others have stated, the 3 point setup is category 1
The manual calls out 10w30 diesel oil, but I’ve always run common 15w40, or 5w40
   / Massey Ferguson 1540 Linkage #15
We run Rotella T6 5w-40 for engine oil and we use a Napa 1394 on our 33 hp 1533... you have a larger engine and the filter may be different.
   / Massey Ferguson 1540 Linkage #16
Need a Massey Ferguson Manual?
Go to
www.agcopubs.com
There you can purchase any manual for almost any Massey Ferguson, Allis Chalmers, Agco and all the manufacturers under the Agco umbrella.
Usually reasonably priced. Whether it be an owner manual, service manual, or parts manual.
If you just want to look up parts go at
https://parts.agcocorp.com/us/en.
Again all manufacturers under the Agco umbrella.
   / Massey Ferguson 1540 Linkage #17
I have a massey ferguson 1540 & am not sure if the linkage is regular agri linkage size or smaller compact tractor linkage - how can I measure or find out? silly question maybe, but I dont have an owners manual
Here's a link to a 1547 manual. It seems to be in the 1500 series, too. AGCO MASSEY FERGUSON 1547 SERVICE MANUAL Pdf Download
brochure: https://manualzz.com/doc/56099657/massey-ferguson-mf-1519--mf-1523--mf-1532--mf-1540--mf-15...
Some user groups or forums have a library of manuals.
CAT 930M (A58216)
CAT 930M (A58216)
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2015 TRANSCRAFT/WABASH 48X102 STEEL FLATBED (A58214)
2015...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2023 CAT 249D3 Compact Skid Steer (A59213)
2023 CAT 249D3...
2011 JACK COUNTY 130BBL VAC TRAILER (A58214)
2011 JACK COUNTY...
