Making hard line - fittings needed
   / Making hard line - fittings needed #1
john_bud
Super Member
Hi,
I need to make some hard lines up. I can bend the lines up, but need to weld, braze, silver solder fittings on. 3/4 line going to a 1/2 Oring boss or 37 JIC.
Anyone have a source ?
Thanks,
jb
I've got swagelok for 1/4 and 3/8, but not for 3/4.
I also want it to be more robust as the hard line in going to be inside a hoe boom and it has to be able to take a LOT.
I will take a look...
   / Making hard line - fittings needed #4
Did you try J & D Tube bending out of Schofield ? I have seen some of their work and their bending forms are very pleasing to the eye.
Joes...
I have all the skills in the world for bending these tubes (they are straight!!). What I need are fittings that make a 90 degree turn and go thru a bulkhead. It really shouldn't be that tough, I'm just looking in the wrong places or using the wrong google words. I can get billions of hits that I don't want! Pounding head on desk....
And, no I didn't try J&D, but I will look....
Thanks,
jb
   / Making hard line - fittings needed #6
John, I just tried to locate some. Now there is two sore heads.:mad:
Can your local tubing supplier be of help or say a local backhoe dealers service shop?
YEah, tired those. May have to go to a ferrel type solution, but I REALLY REALLY want a silver solder, braze or weld on 90 degree bulkhead for 3/4 steel pipe.
The stinking backhoe is full of them! They can't be that impossible to find ... banging head on table ... they just can't be...
can they?
j
   / Making hard line - fittings needed #10
john_bud
why not use the furrel fitting and throe out the nut and furrel and braze them to gether
from discount hydraulics
or use 27208-12-12 compression adaptor and 6500bt-1212
or give them a call mabe they have what you want but not on internet?
tommu56
Toro Dingo Mini Skid-Steer Mounting Plate (New/Unused) (A59225)
Toro Dingo Mini...
2024 Yakta YXR120 Zero Turn Lawnmower (A57453)
2024 Yakta YXR120...
Giyi Breaker Hammer (A57149)
Giyi Breaker...
2019 KENWORTH T800 HOTOILER (A58214)
2019 KENWORTH T800...
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A56857)
2025 Kivel Fork...
26ft x 42ft Double Garage All Metal Building (New/Unused) (A59225)
26ft x 42ft Double...
