Making hard line - fittings needed
   / Making hard line - fittings needed #1
john_bud
Super Member
Hi,
I need to make some hard lines up. I can bend the lines up, but need to weld, braze, silver solder fittings on. 3/4 line going to a 1/2 Oring boss or 37 JIC.
Anyone have a source ?
Thanks,
jb
I've got swagelok for 1/4 and 3/8, but not for 3/4.
I also want it to be more robust as the hard line in going to be inside a hoe boom and it has to be able to take a LOT.
I will take a look...
   / Making hard line - fittings needed #4
Did you try J & D Tube bending out of Schofield ? I have seen some of their work and their bending forms are very pleasing to the eye.
Joes...
I have all the skills in the world for bending these tubes (they are straight!!). What I need are fittings that make a 90 degree turn and go thru a bulkhead. It really shouldn't be that tough, I'm just looking in the wrong places or using the wrong google words. I can get billions of hits that I don't want! Pounding head on desk....
And, no I didn't try J&D, but I will look....
Thanks,
jb
   / Making hard line - fittings needed #6
John, I just tried to locate some. Now there is two sore heads.:mad:
Can your local tubing supplier be of help or say a local backhoe dealers service shop?
YEah, tired those. May have to go to a ferrel type solution, but I REALLY REALLY want a silver solder, braze or weld on 90 degree bulkhead for 3/4 steel pipe.
The stinking backhoe is full of them! They can't be that impossible to find ... banging head on table ... they just can't be...
can they?
j
   / Making hard line - fittings needed #10
john_bud
why not use the furrel fitting and throe out the nut and furrel and braze them to gether
from discount hydraulics
or use 27208-12-12 compression adaptor and 6500bt-1212
or give them a call mabe they have what you want but not on internet?
tommu56
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
2014 Ford Fusion SE Sedan (A56859)
2014 Ford Fusion...
2020 KOMATSU PC138USLC-11 EXCAVATOR (A52709)
2020 KOMATSU...
2002 Freightliner (A57148)
2002 Freightliner...
2012 Terex TA400 Articulated Dump Truck (A59213)
2012 Terex TA400...
