Making hard line - fittings needed
   / Making hard line - fittings needed #11
JB:
Tommu56 has a good suggestion with one change. I used the Discound Hydraulics flareless fittings on 3/8" and 1/2" tube with great success. As you know from the Swage-Lok two ferrule fittings, the ferrules slip down around the tube and part way into the end fitting. The nut then pushes the ferrule down further into the fitting to swage it onto the tube. If you leave out the ferrule there will be a pretty big gap between the inside of the fitting and the outside wall of the tube. Melted silver solder or brass will pool in that space and probably leak into the fitting around the end of the tube.
But if you use the ferrule and nut, and then braze the nut/thread interface and nut/tube interface you will have a "double seal" that should solve your problems. Brass or silver solder should wick into the joints well enough to make everything tight.
And think of the looks you will get from your friends when they try to figure out why you welded the screw on fittings.
2252 (A58376)
2252 (A58376)
Hyster H80FT 8,000LB Forklift (A56857)
Hyster H80FT...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
2016 Husqvarna YTA22V46 46in Riding Mower (A56859)
2016 Husqvarna...
