Making '06 HPX Diesel Like XUV?
   / Making '06 HPX Diesel Like XUV? #11
the tires didn't take much power away from the hpx. i sink mine down in the mud till the water and mud is almost coming into the air vent on the clutch enclosure and they keep turning .i run them through a cane field and get them caked with about 4"of mudd and they keep on turning now i do keep it in low gear when doing that kinda mud riding but it has no problem turning a 27"tire. but if i was to do it again i would go with a 26"589 itp it has the same tread debt and it won't rub my 27's rubbed when i first got them till i wore a little bit of them.
   / Making '06 HPX Diesel Like XUV? #12
There's a different design to the XUV clutches as I understand it they are much more advanced. As for putting a bigger belt on I highly doubt that would work because the belt that it comes with fits pretty snugly.
   / Making '06 HPX Diesel Like XUV? #13
is your hpx out of warranty ? if so why not just experiment wth it . try different things going with a wider belt might make it bite sooner you never know if you have the money try it thats how things get improved people try stuff and say hey that worked. but you might be onto something with the wider belt.i would have to see both belts sideby side to see the diferense in them.
   / Making '06 HPX Diesel Like XUV? #14
There was a question on weight between the HPX and XUV. The XUV is nearly 100 pounds heaver. HPX- 1296 pounds. XUV- 1383 pounds.
UNUSED SDLANCH SDLD25 CRAWLER DUMPER (A57192)
UNUSED SDLANCH...
Hose Reel (A55758)
Hose Reel (A55758)
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
2013 Ford Taurus Sedan (A55853)
2013 Ford Taurus...
UNUSED JCT HYD TRENCHER (A57193)
UNUSED JCT HYD...
15ft Batwing Rotary Brush Cutter Tractor Attachment (A55851)
15ft Batwing...
