Maintaining Two Batteries With One Maintainer....
   / Maintaining Two Batteries With One Maintainer.... #1
Utopia Texas
Platinum Member
Brookshire & Cat Spring,Texas
Kubota B2650 / Kubota L6060 / Kubota ZD2300
If two 12v automotive batteries are connected together with a battery switch will a maintainer on one take care of both batteries at the same time? Will a small 2 amp maintainer unit keep up two batteries if they are in good shape or should a larger amperage unit be used? thanks...
   / Maintaining Two Batteries With One Maintainer.... #2
If the switch keeps both batteries connected they will act as one battery. The two amp should maintain them if they are in good shape.
Any recommendations as to "Brand"?
There appears to be dozens of units on the Internet at really varied prices.....
   / Maintaining Two Batteries With One Maintainer.... #4
These units tend to send high frequency pulses to the batteries to break loose the sulphation. I have a friend that has six or so batteries connected at once to one small unit. I find this obsession with your batteries a bit over the top, myself. Better have fuses on each line though as batteries have a lot of stored energy!
Some are very expensive and some from China (on E-Bay) are very cheap. I suspect that certain cheap ones are as good as the domestic high cost ones. I was looking into getting one, but got side tracked.
So unfortunately, I can't reccommend which cheap ones to buy. I would probably go with a cheaper one that has some technical information, not just claims like " batary lasting very long time" or "make stronger start". You get the idea.
   / Maintaining Two Batteries With One Maintainer.... #5
Wire diodes in a way that current can't flow any way but toward each battery from the charger. (Remember those isolator kits for cars trucks that had 3 posts on a large heat sink? Same deal, and you don't want a circulating current loop between the batts.) Whichever one can use the charge will take it, but they won't be going back & forth between each other this way. (not so good for them)
You can set up a bench charger with a diode on each + of several take-offs or clip sets. They will divide the current according to their state of charge. Chargers' no load vs loaded voltages will vary, so be less concerned with voltage when charging. After any charging cycle give the batteries a 1/2 - 1hr rest before checking voltage. 12.7v NL means they're in good shape.
btw, Just prepped a 'dry-charged' batt for boss' quad. Instructions said to wait 1/2 hr after adding acid before charging and to charge at 2A with a floating circuit charger (14 A/Hr batt, btw) then rest another hour before use. The battery will still work if you rush thru this, but useful life will be shorter. (BTDT with puny 16 A/Hr batts in 'big twin' motorbikes w/o kick start & lucky to ever get two seasons out of one. AGM batts are better when sized small for load and are shipped 'wet')
It's a good idea to trickle any unused battery as all lead-acid types will self-discharge over time, and being on concrete can't be blamed anymore (old myths die hard), nor can greasing/sealing terminals prevent it. I built a YouTuber light bulb 'regenerator/desulfator' (high V, low A pulses, w/1A fuse) and have had good success recovering batts that have no cells shorted internally. No-load voltage reads high on meter's DC scale, but falls right into the mid-13s - 14v when connected.
Battery life is inversely proportional to time spent at full charge, the reason your daily driver's battery lasts so long. Topping up is as important a routine as checking tire pressures, lug nuts/bolts or loader bolts but doesn't ever have to be as much work. tog
   / Maintaining Two Batteries With One Maintainer.... #6
A diode junction will give you a .6 volt drop! Not sure if that would matter with HF pulses though, but if it is also a charger, you would loose .6 Volts.
I can't understand why my GMC gauge seems to show 16 or so volts and doesn't boil my batteries dry with it's HD alternator, in no time at all?
   / Maintaining Two Batteries With One Maintainer.... #7
Of the latest types, I have the Ctek 3300.
Battery Chargers - CTEK Battery Chargers
It is more money than some of the basic ones. Why it's worth more money to me:
1) Puts out 3.3amps max. Decent capacity vs. compact case size. Easy to tuck into smaller spaces.
2) Does have de-sulphation mode.
3) The unit is well sealed against water and dust (IP rated). I can use it outside in less than ideal weather.
4) It has a cold weather/AGM mode. Standard flooded lead-acid batteries benefit from a higher charge voltage in cold weather. AGMs like a higher charge voltage in general.
I'd stay away from the $8 tenders - a few folks have cooked batteries on the stuff Industrial is warning about. Battery Tender seems to be popular, but it's one I haven't tried.
Automotive
Around here I can find CTek or Bosch equivalents for less money than Battery Tender.
Rgds, D.
   / Maintaining Two Batteries With One Maintainer.... #8
I have 2 outboard deep-well batteries that I use for the trolling motor on my boat, that are connected in series. I left them connected in series when I removed them from the boat for winter storage, and connected my Battery Tender Junior. It has done a great job of keeping both fully charged.
   / Maintaining Two Batteries With One Maintainer.... #9
Are those 6 volt batteries, or do you have a 24 volt charger Aaron ?
Rgds, D.
   / Maintaining Two Batteries With One Maintainer.... #10
Rgds, D.
I apologize, I meant connected in parallel, not series! 12 volt batteries with a 12 volt charger.
2008 GMC Acadia SLT1 SUV (A48082)
2008 GMC Acadia...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A51039)
2016 Ford F550 4x4...
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
Misc. Office Furniture (A50860)
Misc. Office...
2012 Dodge Grand Caravan Van (A48082)
2012 Dodge Grand...
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
