mahindra 3510 final drive cap leaking
   / mahindra 3510 final drive cap leaking #1
scrufy12
Mississippi
mahindra/3510
Can any one tell me how to replace the cap on the bottom of the final drive assembly? Can it be remove without taking the entire assembly apart?
   / mahindra 3510 final drive cap leaking #2
Welcome to TBN. :)
   / mahindra 3510 final drive cap leaking #4
You should post in the Mahindra forum for these questions. Yes, you can replace that cap. On my 4110 you remove the 3 bolts and flat plate covering the cap. You can drive a punch or screwdriver thru it with a hammer and pry it out just like a freeze plug - which it is pretty much except that it is rubber coated. Carefully and evenly tap the new one back in and refill the outdrive with 90w.
   / mahindra 3510 final drive cap leaking #5
WELCOME to TBN :)
I moved your thread to the Mahindra Owning/Operating Forum.
My Mahindra is the 2005 new sheet metal model and i don't think there are any bolts to remove. Would I still remove the cap by prying it out with a screwdriver or punch? Sorry about posting the previous comment in the wrong forum.
   / mahindra 3510 final drive cap leaking #8
Your axil is a newer style than Skips, and yes that should just pry out of there, put sealant on the new one and tap it up in.
Payment Terms (MUST READ) (A50775)
Payment Terms...
Craftsman Belt Driven 12 in. Band Saw-Sander (A50860)
Craftsman Belt...
2022 Club Car...
1996 Eager Beaver 44ft. 50 Ton Tri-Axle RGN Lowboy Trailer (A49461)
1996 Eager Beaver...
Cat 60" Wheel Loader pallet Forks (A49461)
Cat 60" Wheel...
2022 Club Car...
