Mahindra 3215 starts but dies after a few seconds
   / Mahindra 3215 starts but dies after a few seconds
Does anybody have a electrical wiring diagram for this tractor? I bought this tractor used and don't have any of the manuals for it. Thanks
   / Mahindra 3215 starts but dies after a few seconds #12
Don't know where the fuel solenoid is on your model, but on my Max 22 it is located just above the oil filter and behind the throttle cable. My Max 22 was exhibiting the same symptoms. After browsing some forums I was also directed to the fuel shutoff solenoid. I pulled the solenoid and tested it on the bench. It would pull when the pull winding was energized (about 24 Amps) but the hold winding was not able to hold it in the pulled position when pull was released. I considered rigging it to just use the pull winding to hold it closed, but at 24 amps I think that it would burn up the winding pretty quickly. In any case, if you can pull the solenoid and test it at your dad's place it should be a pretty quick and easy test and let you know if you need to order a new one.
awsomefx, thanks for the information. I will see if I can figure out where the solenoid is and try to test it.
So I finally found the fuel shutoff solenoid, it was located behind the fuel filter. It is really hard to see and the only way I found it was by tracing wires. It looks like the solenoid is bad. Does anybody know where a good place to buy a solenoid for a decent price is?
1240 (A50490)
1240 (A50490)
2018 John Deere 35G Mini Excavator (A49461)
2018 John Deere...
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
F-500 POWER PUMP 500HP TRIPLEX POWERED BY 3412 CATERPILLAR ENGINE (A50854)
F-500 POWER PUMP...
1994 FORD F450-SUPER DUTY FLATBED (A51219)
1994 FORD...
Craftsman T1800 42in. Riding Mower (A49346)
Craftsman T1800...
