3-Point Hitch Mahindra 3215 3-Point Stabilizer Bars
   / Mahindra 3215 3-Point Stabilizer Bars #1
kospiller
Winfield, Alabama
Mahindra
Has anyone else experienced any problems with stabilizer bars bending on a 3215. I have a 2006 model and had them replaced under warranty after straightening them and welding. The second set have both broke now multiple times and been welded back. I use a rotary cutter, boxblade, tiller and disk. It appears to me to be a poor design with a lot of slop everywhere.
Has anyone replace them with something else?
   / Mahindra 3215 3-Point Stabilizer Bars #2
I agree, very poor design. I altered mine to get a more rigid design. I got some link end repair pcs and welded them in as you can see. The ball swivel fit right over the existing stud that is there. I pulled those pieces off and drilled and tapped and studded them so that I have a lock nut and washer holding the arm on. This has worked very well for me and is far superior to the OEM design IMO. ;)
MtnViewRanch,
Thanks for the reply. Could you supply some more detailed pictures?
   / Mahindra 3215 3-Point Stabilizer Bars #5
I have broken my stabilizers twice - the piece with the hole in it that slides into the sleeve with holes - replacements are over $100 and the metal is pot metal or cheap steel. If you could show a closer up picture of the gizmo you fixed I'd appreciate that. I have a 3016 model.
Thanks,
   / Mahindra 3215 3-Point Stabilizer Bars #6
Here are a few, hope that these help. Feel free to ask any questions. ;)
   / Mahindra 3215 3-Point Stabilizer Bars #7
Excellent, thanks for the pictures!
   / Mahindra 3215 3-Point Stabilizer Bars #8
You're welcome. I would like to say that I did not make the change because I broke anything. I made the change because I hated all the monkey motion that was there with the OEM linkage. I made the change within the first month of having the tractor, it has worked out VERY WELL for me. ;)
2007 GMC Yukon XL SLE SUV (A48082)
2007 GMC Yukon XL...
2005 Sterling Acterra Tender Truck (A51039)
2005 Sterling...
2016 Big Tex 12ft. S/A Utility Trailer (A48082)
2016 Big Tex 12ft...
2016 CATERPILLAR 259D SKID STEER (A50458)
2016 CATERPILLAR...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
Case 84in Hydraulic Hopper Sweeper/Broom Skid Steer Attachment (A49461)
Case 84in...
