Mahindra 3016 HST backhoe 3720 will not work
   / Mahindra 3016 HST backhoe 3720 will not work #11
Rick
I presume there is a hose that you have to connect when back hoe is not mounted so the 3 point hitch operates. Is this correct?
If yes then can you trace one of the lines back to the loader valve? This would be power beyond on the loader and should connect to pressure on the back hoe. Other line would connect to power beyond on backhoe.
3rd line on backhoe should be tank and connect directly to tank connection
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
2009 INTERNATIONAL DURASTAR 4300 SBA ROAD TRACTOR (A58375)
2009 INTERNATIONAL...
2023 Kubota L6060HST Compact Utility Tractor (A56436)
2023 Kubota...
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
