Mahindra 2615 Hydro - 2007
   / Mahindra 2615 Hydro - 2007 #11
Dave is heading you down the right direction he, but I would try one thing different first. On the right side loosen the bolt that attaches the fuel lines to the side of the fuel injection pump, turn the key to the on position and you should hear the fuel pump ticking. When fuel comes out at your loosened fitting tighten the bolt and try to start the tractor. You could also check the fuel for gasoline or water at this point. If that doesn't work, move on to Dave's suggestion to see if you are getting fuel at the injectors, and then on to the glow plugs. If your fuel system has lost its prime, loosening the fuel line process will reprime the system. Good luck and let us know.
For sure, that should be first. Good call. Also the post regarding how to check the glowplugs is good.
We are amazed how often intelligent and careful people somehow get fouled fuel. Usually the culprit is water, the second most common is gas. So don't overlook this issue.
HELLO TO ALL...
SORRY I HAVEN'T POSTED IN AWHILE...I WAS AWAY. BUT,MY TRACTOR IS FIXED....IT WAS THE GLOW PLUGS...AND I THINK I AM THE REASON, I WAS USING A BATTERY CHARGER ON HIGH CHARGE AND TRIED TO START HER AND I THINK I BURNED OUT ALL THE GLOW PLUGS. I REPLACED ALL THREE AND SHE STARTS LIKE A CHARM...THANK YOU ALL SO VERY MUCH FOR THE HELP, IT WAS MUCH APPRECIATED...ENJOY THE HOLIDAYS...AND BEST WISHES FOR A BRIGHT AND HAPPY NEW YEAR...
Misc. Trimmers and Chain Saws (A50860)
Misc. Trimmers and...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2012 John Deere 7280R MFWD Tractor (A51039)
2012 John Deere...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
Craftsman LT2000 42in. Riding Mower (A49346)
Craftsman LT2000...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
