Comparison Mahindra 2538 or Kubota 3901 anyone have experience with both.
   / Mahindra 2538 or Kubota 3901 anyone have experience with both. #61
Geez, my insurance is a rider with my homeowners and its 50 bucks a year, on or off my property, on or off a trailer. Full coverage and includes all implements.
   / Mahindra 2538 or Kubota 3901 anyone have experience with both. #62
The disk will be used mainly to disk greenfields sometimes places we put them can be rocky or have stumps and such. Everybody I know uses a disk for such places so you tear up your tiller. And the disk is faster in those applications because you don't need such a fine seed bed.
Good call on that. Disk when you can, use the tiller for smaller areas and where you need a real fine result. A tiller seems to be about the hardest thing on a tractors PTO system. It helps if the tiller has a slip-clutch in case you wrap up a piece of rebar or grab a stump solidly.
   / Mahindra 2538 or Kubota 3901 anyone have experience with both. #63
Called my dealer today and got a price for adding a couple more implements. All the implements for the Mahindra are with Mahindra implements which the dealer said was made by Kodiak, the Kubota is with Landpride. Not sure if one is better than the other. And as Dave had stated in a previous post this caused the better deal at the Mahindra dealer to be the 0% price on the tractor. So both of these prices are with 0% financing for 60 months. So the price I have now is with tax included only thing not included is Insurance. Kubota Dealer said it was approx $34 a month and I didn't ask the Mahindra dealer but I would think it would be about the same I really wish there was a couple thousand dollars difference in the price so the decision would be a lot easier. For some reason I always thought Mahindra's were cheaper. Maybe they use to be.
FEL on both
20' Trailer with brakes on rear axle.
5' MD Cutter
5' Tiller
5' Box Blade
5' Disk (tube not angle)
Mahindra = $31,262 - 0% 60 months 521.03
Kubota = $30,940 - 0% 60 months 515.66
Just a thought on the trailer- would suggest getting trailer brakes on both axles.
also from some posts on tbn it may be required by law in some states.
   / Mahindra 2538 or Kubota 3901 anyone have experience with both. #64
Fallon, contractors use a disc then tiller/ powerharrow on greenfield cultivation because it saves the accelerated wear and tear running a tiller directly into grass. Also if you hit stumps or rocks, disc handle them better as the shock loads are far less.
   / Mahindra 2538 or Kubota 3901 anyone have experience with both. #65
That is exceptional. Typical HO3 policies cover equipment used on the property for maintaining the property, but not if used for hire, and not if taken off the property, and they will sometimes have a dollar limit. The idea is to cover a riding lawn mower for no charge. The idea is not to cover $30k in equipment for free. Sounds like you are good to go with the rider. It is always smart to check. If I recall correctly, in California (it varies by state) the insurance for a Mahindra through a dealer is around $6/$10k/mo. So $30k would be around $18/month. Pretty cheap really compared to auto insurance for physical damage, but it does all add up.
   / Mahindra 2538 or Kubota 3901 anyone have experience with both. #66
Agreed. I have 60 trailers on the lot, and 100% of the tandem trailers have brakes on both axles. And all have the larger 2-5/16" coupler. It's proper that way and does not cost that much more.
   / Mahindra 2538 or Kubota 3901 anyone have experience with both. #67
It will be an HST. I had thought about a 2501. But I felt like it would be underpowered for running a 5' cutter or even pulling a set of disk. Maybe not since I never ran one. Maybe someone that has one can chime in.
Just asked in another thread what the PTO rpms are on the L2501. The max hp rating on my L3200 is 2800 rpm. The max HP rating on the L2501 is 2200 rpms.
I have a suspicion that if you look carefully enough, you'll find that "missing" 9hp. If the PTO speed is 2800 that more or less proves it.
   / Mahindra 2538 or Kubota 3901 anyone have experience with both. #68
Looks like you have a tough call. The Kubota boys come out in force with their pom poms whenever they see the word kubota. The Kubota is a fine tractor. The Mahindra is a fine tractor. The Kubota may hold it's value longer but unless purchasing for resale that is only a small bonus point. I like my 2538 a lot. It does spec out better but that is on paper. //
Red pompoms! Very becoming!
Orange is the new black, though, I hear!
   / Mahindra 2538 or Kubota 3901 anyone have experience with both. #69
Now your are revealing industry secrets. :) In the Mahindra world, the Mitsu S3L2 engine has been used in many models rated at 24, 25, 26 and 28 HP. The only difference that I see is the rated RPM. A little more speed, a little more HP. The new 1526 is nearly a twin to the old 3016, but rated at a lower HP to get under the 19kw Tier IV norms. It is smart to consider these models if they are adequate for the job.
   / Mahindra 2538 or Kubota 3901 anyone have experience with both. #70
Detroit used to understate HP all the time in order to help keep the insurance industry in check. Now all the emphasis and lying seems to be about mileage and the CAFE standards. Well except for VW maybe.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
12' CONTAINER (A57193)
5' MOWER (A52706)
5' MOWER (A52706)
UNUSED WOLVERINE TQH-26-01C 3 PT QUICK HITCH (A57193)
UNUSED WOLVERINE...
Kubota L4701 (A53317)
(2) 16" X 30# X 152" (1) 16" X 31# X 187.5" I-BEAM (A57192)
(2) 16" X 30# X...
