CalG
Super Member
- Joined
- Sep 29, 2011
- Messages
- 5,777
- Location
- vermont
- Tractor
- Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
Sort of a general technical question on how these little components do the job of replacing a set of points and condensor.
I have a walk behind mower with a Kaw FC400v engine that failed to produce spark yesterday. It's been "difficult" to start for years, but always would take off eventually. Yesterday is was a couple of bangs as it fired at the wrong time, then nothing even with a new plug.
So the little "Made in Australia, Power Start" module sold by Power Lawnmower Parts out of Rochester NY. is now here at my desk, The plastic case appears weather cracked so I ordered out a Mega Fire universal unit described as a replacement for the OEM 21119-2161. ($16 vs $56 for the Kawasaki unit on line)
But while I wait, a question..... How do those devices work? What determines just when the spark is formed? (timing?) I can appreciate that the FW magnet and the coil position can act as a rough timing trigger, but have not yet caught the jist of how that little igniter does it's job to replace the timing aspect of mechanical points. How does it know? Or perhaps it doesn't matter.
I've seen Briggs electro-magic coils with an additional magnetic sensor, but the item I'm speaking of is screw mounted to a light bracket on the side of the crankcase. There is no mechanical connection to the flywheel position.
I'm OK with electronics and components, so fire away!
TIA
Cal
TIA
Cal
