Made My Quick-Hitch Work
   / Made My Quick-Hitch Work #1
DK_Farms
South Louisiana
JD 4610 E-hydro 4WD, JD 5525 4WD Cab, JD 4066R
I know we have beat this subject to death, but I wanted ya'll to know that I have had success with my Quick-Hitch. After struggling the last few months to hook up my MX6, for which my tractor has to be in EXACTLY the right position +/- 0.0010 inches /forums/images/graemlins/grin.gif, I decided to try the quick hitch route. I ended up with the SpeeCo hitch. It works great on the MX6 and I use the flex coupler on the top link. I tried the hook, but even though it's iMatch compatible, the hook height adjustment plates hit the A-frame before the hook is in position. I guess this isn't a problem for the iMatch coupler since the hook is welded to the hitch and sits slightly further back. At any rate, the flex coupler took care of the mismatch. I also made it work with my box blade as well. The top link pin sat about 1/2 inch too far back to completely engage the hook but making the top link hole slightly elliptical toward the front with my "Victor Fire Drill" solved that problem nicely. I replaced the bolts that hold the hook with quick disconnect pins for easy install/removal of the hook. Now if I could design a self-coupling PTO shaft I'd have it made. The grooming mower doesn't fit (yet!!) but I have come up with an easy modification that I'll try soon. All in all, it seems like a good decision so far.
   / Made My Quick-Hitch Work #2
<font color="red"> </font> Now if I could design a self-coupling PTO shaft I'd have it made. <font color="red"> </font>
Let me know when you have this down pat!
   / Made My Quick-Hitch Work #3
<font color="blue"> I use the flex coupler on the top link </font>
Could you show a picture of that? I have the Speeco, also, and would like to see how you used yours.
   / Made My Quick-Hitch Work #4
I ended up making a new top hook out of 1" thick plate and moved the pin hole 1" rearward to let my stuff up.
Gary, next time I get the cutter hooked up I'll try to remember to take a picture for ya.
Hoeman, I thought about doing the same thing with a piece of 1-1/2 inch plate I have been using as flat anvil, but I'd have to take the plate to a machine shop to get the pin holes drilled out. I don't have anything that stout and the "fire drill" wouldn't do a good clean job. I'm definitely going to put that on my winter time project list though.
E-Z-Go Terrain 1000 G Electric Utility Cart (A55851)
E-Z-Go Terrain...
2004 MANAC 48FT CURTAIN SIDE SPREAD AXLE TRAILER (A57880)
2004 MANAC 48FT...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
UNUSED FUTURE CAT 305 EXCAVATOR AUGER DRILL (A57193)
UNUSED FUTURE CAT...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
ARBOR PRESS (A57192)
