M9000 loader hydraulic lever and all rams leak
   / M9000 loader hydraulic lever and all rams leak #1
B&e recovery
Ford 4500
Man all my front loader Rams leak and now all the sudden the lever sprays out of it I can't even drive my tractor what do I do is there a rebuild kit for all of it I don't
   / M9000 loader hydraulic lever and all rams leak #2
Welcome to TBN
1st thing I'd suggest to do is check hyd system pressure. With that number of leaks it sounds as if hyd pressure is too high. Kubota LA1301 loader spool valve schematics lists a spool seal o-ring kit.
   / M9000 loader hydraulic lever and all rams leak #3
Something is very screwey. Sounds to me like your hydraulic pressure is way too high. Two of the loader cylinders on one of my M9's weep slightly but the tractor has over 6000 hours on it and a lot of loader work moving and loading round bales. If it gets worse I'll probably pull them and take them to a local hydraulic shop to get rebuilt but none of my valving leaks at all which leads me to believe you pressure is way too high.
   / M9000 loader hydraulic lever and all rams leak #4
Not uncommon with my 30 years of ownership Have 4 Kubotas and I have seen over the last 2 decades of using them in farming & mowing that Kubota uses seals that develop leaks earlier on than my other brands of tractors & equipment.
I have developed several seal failures over the years. In fact, it’s the most common issue I have with their brand.
Your case sounds different. Are you the original owner? Any chance a previous owner fiddled with pump/pressures?
   / M9000 loader hydraulic lever and all rams leak #5
Sounds like it might be highly restricted / dead headed. Pressure has to go somewhere.
   / M9000 loader hydraulic lever and all rams leak #6
Deadheaded hyd pressure should not cause FEL cylinders to leak unless FEL control valve is the reason for the deadheaded oil
Master MGH8500IE 8,500-Watt Generator - Electric Start, 18HP Honda Engine (A51039)
Master MGH8500IE...
2025 K2030 UNUSED Metal Garage (A50860)
2025 K2030 UNUSED...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
Tractor Steel Bumper and Grill Guard (A50860)
Tractor Steel...
Okada Top 270 Hydraulic Breaker (A50860)
Okada Top 270...
UNUSED Clear Corrugated Polycarbonate Roof Panels (A50860)
UNUSED Clear...
