M7060 cab model, range gear change stiff for creep speed
   / M7060 cab model, range gear change stiff for creep speed #1
RoyKing
Platinum Member
Gainesville Florida
M7060HSC/18, RTV-X1100C
Pretty stuff getting into creep, neutral and clutch in helps. I know some people say park is stuff but mine is fine.
   / M7060 cab model, range gear change stiff for creep speed #2
New Machine?,if so it will get better with use.If not may want to look at lucubrating
linkages.
   / M7060 cab model, range gear change stiff for creep speed #3
My M6040 took a couple years of use before the range selector was smooth & easy.
Already shifting easier, helps tranny neutral, clutch in, you can feel the gear sets move and grind so clutch in stops the grinding
2025 40ft. High Cube Shipping Container w/ 1 End Door & 4 Side Doors (Est. Retail Value ($12,000)... (A59225)
2025 40ft. High...
2009 Ford E-350 Cargo Van (A56858)
2009 Ford E-350...
Portable Restroom (A54865)
Portable Restroom...
2005 INTERNATIONAL DURASTAR 4400 24FT BOX TRUCK WITH LIFT AXLE (A58017)
2005 INTERNATIONAL...
NEW Fork Extensions (A59000)
NEW Fork...
2015 TRANSCRAFT/WABASH 48X102 STEEL FLATBED (A58214)
2015...
