M7040 wont start
   / M7040 wont start #1
remington270
Alabama
Kubota M7040, Kubota B2710
Cut my tractor off today after discing, and couldn't get it started again. Battery works, fuses intact, dash board says PTO is engaged, which is not the case! I think the tractor "thinks" PTO is on, which prevents tractor from starting. Anyone had this problem before? Tractor is a kubota m7040. Thanks for the help...
   / M7040 wont start #2
Definitely won't start if it thinks the PTO is engaged.
You probably tried moving the PTO lever to engage / disengage several times.
The only other thing to do is check to see where the switch is that senses the PTO lever position. If it is something simple like a seat switch you should be able to fool it.
   / M7040 wont start
I have tried turning the pto on then back off repeatedly with no luck. Ive looked at the manual but can't seem to find where the switch is that controls the pto mechanism being turned on. Right now my tractor is spending the night under the stars in a big field.
   / M7040 wont start #4
The switch will be on the pto lever somewhere unless you have the button then the switch will be part of the pto button(switch).
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
2017 Ford F-550 Valve Maintenance Truck (A50323)
2017 Ford F-550...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
2018 John Deere 460E Articulated Dump Truck (A51039)
2018 John Deere...
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
