M7040 or M6800, How big of Tandem Disc
   / M7040 or M6800, How big of Tandem Disc #1
fishinglth
I am considering purchasing a M7040 or M6800. The land in my area is very tight red clay. Does anyone have experience with either of these two tractors pulling a tandem disc? I am just wondering how big of disc I might be able to pull? Do you think these tractors would pull a 10 footer?
   / M7040 or M6800, How big of Tandem Disc #2
Well, I think the 7040 is rated for 3-14 plows... it may be 3-16's, so i would think that a 10' disc would be too small. My guess is that is is probably well suited for a 14' disc..maybe more. I pulled a 14' disc with my old 670 minneapolis-moline with the same horse power as the 7040 and only 2WD. If it would have had 4wd, i'd be driving it today.
Don
   / M7040 or M6800, How big of Tandem Disc #3
The m7040 is rated for a maximum size disc harrow (drawbar type) of 10'. It is limited to 8' and 1200# with a 3ph type. Those are with 4WD. It's a little bit less with 2WD. The max. size plow is 16 in. x 3 bottom. But I would probably recommend a 14 x 3. That's what I'm looking to get. You will be very hard pressed to find a new m6800 anywhere now. You could probably realistically push beyond these implement limitations in the real world, depending on your soil type and conditions, but I wouldn't recommend it.
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2015 PETERBILT 367 HOT OIL (A50854)
2015 PETERBILT 367...
2015 DODGE RAM...
2014 INTERNATIONAL PROSTAR (A50854)
2014 INTERNATIONAL...
Sentry Supreme 5330 Safe (A48083)
Sentry Supreme...
UNUSED Stainless Steel Sink (A50860)
UNUSED Stainless...
