M7040 Logging
   / M7040 Logging #1
atilton
L4310, M7040, KX161, RTV900, RTV1140
Just a couple pictures of My M7040 at work
   / M7040 Logging #2
holy smokes, what a nice way to make wood....:D
have made firewood for many years the old fashioned way of cutting it into chunks in the woods and manhandling it home and into the woodshed.... Have a M4900, wonder if it can run one of these operations... some leg work to do....
thanks for the info.....
   / M7040 Logging
I wouldn't go any smaller than a 60 hpr tractor mainly becuase of the weight you need somthing good and heavy in front of that trailer when it is loaded going up or downhill, I would say that is about 6 1/2 ton including the trailer. It's a little overloaded in that picture I just wanted to see what it could do.
   / M7040 Logging #4
wow....nice set up!
I'm very jealous.
   / M7040 Logging #5
How do you like the self loading trailers hydraulic arm? enough power? how about fully extended down a hill? lift capacity? What do you think?
Ive seen them in Baileys supply and always wondered, looks like a good investment and cheaper and more versatile than a self loading log truck
Thinking i could use it to haul logs to mill.
   / M7040 Logging
this model is one of the smaller ones but it works great for what I am doing it will pickup a 15' x 18" log fully extended. Mine reaches out 16 feet and will pick up 1200 lbs at 16 feet. on abigger log I just grab it and pull it in closer to the trailer and then lift it on. For the rest of your question I like the loader it seems well built and smooth running. if you where looking for something bigger they make models that have the same boom as mine and then it will telescope out and has more lift power.
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2014 Peterbilt 320 Altec AH150 Boom Truck (A49461)
2014 Peterbilt 320...
Seppi Mini BMS 85 Mulcher excavator attachment (A51039)
Seppi Mini BMS 85...
DODGE PICKUP BUMPERS (3) (A50854)
DODGE PICKUP...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2021 ALLMAND BROS, INC. NIGHT LITE LIGHT TOWER (A50854)
2021 ALLMAND BROS...
