Thanks for the replys.
I have looked at
Surplus Center but wonder if the flow was lowered the pressure regulator on my tractor would stay open and that would overheat my fluid.
The reel is operated with a hydraulic motor that is rated 12 GPM @ 1500PSI. My tractors system is 11 GPM @ >2500 PSI.
I had a thought to tee in a pressure regulator set @ 1600 PSI with the output running back to the tractors hydraulics through a cooler. Then install the flow regulator in the 1600 PSI area of the circuit.
Thanks, Scott
