M7040 Hydraulic question...
   / M7040 Hydraulic question... #1
samofsweden
Kubota Bx24, 2007
Today I bought a "crane-trailer" for my M7040 (pics will come later). The crane needs so called "free return to tank" to work. I haven't found anything back on the M7040 except where you fill hydraulic oil, which could work as a free return. I know it can be an issue to use the oil filler hole as a return, return oil can create air bubbles.
Thanks for help!
/Sam
   / M7040 Hydraulic question... #2
You should be able to tee into the return hose anywhere you find it.
If you just have to, you can bore a hole in the filler cap. It has been done before.
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2007 John Deere TX 4x2 Utility Gator (A49346)
2007 John Deere TX...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
18 Misc. Tech (Tesira, AMX) (A48083)
18 Misc. Tech...
UNUSED U Bolt Wire Rope Clamp Set (A50860)
UNUSED U Bolt Wire...
