M7040 "hissing" noise from under seat?
   / M7040 "hissing" noise from under seat? #1
nauxier16
Bronze Member
Red Bush, Ky
2013 Kubota M7040 4wd Hydraulic Shuttle
Hey guys I have a new M7040 4x4 Hydraulic shuttle and I have noticed that it has what sounds like a hissing noise or like an air leak coming from under the seat but everything works great and all the fluid levels are good, i'm not sure if its fluid bypassing a valve or what, i'm not sure if this is a problem or a common thing on these, I was just wondering if you all could help.
Thanks!
   / M7040 "hissing" noise from under seat? #2
I'm thinking rattler?:) Or maybe a cottonmouth?
Have no idea but thought I'd throw in some humor.
Could you have a slow air leak in a tire? Suspension seat leak?
Enjoy your new tractor.
   / M7040 "hissing" noise from under seat? #3
Check that your 3pt is not bypassing at the top of the lift.
What is the best way to check it and if it is doing that how do I fix it? I kinda think its something like whatyour talking about.
   / M7040 "hissing" noise from under seat? #5
do you have an air ride seat that has a leak? Do you hear an air pump continuously running?
No it doesn't have an air ride seat, I'm not aware of it having an air pump
   / M7040 "hissing" noise from under seat? #7
Move 3 pt control lever forward just a little and see if the noise goes away. It's possible the 3 pt is raised to it's upper limit and control valve isn't going into neutral position. If lowering 3 pt stops the hissing noise then I'll guess "feedback rod" is out of adjustment.
Ok thanks a lot, I will try it when I get home from work tonight and I will see if it works.
I moved the 3 point hitch up and down and the sound would stop but when I would raise or lower the hitch it was still noticeable just not as bad
   / M7040 "hissing" noise from under seat? #10
Sounds like you may have had too much chili:laughing:
American Sanders Super 7R Electric Wood Floor Edger (A49461)
American Sanders...
2025 REDEDLIFT CPD25-XD4 FORKLIFT (A51222)
2025 REDEDLIFT...
tiller (A50860)
tiller (A50860)
1268 (A50490)
1268 (A50490)
2016 VOLVO VN SERIES SLEEPER (A50854)
2016 VOLVO VN...
Huffy NEL LUSSO Bicycle (A50860)
Huffy NEL LUSSO...
