Ballast m7040 cast iron wheel weights
   / m7040 cast iron wheel weights #1
m7040
Elite Member
Frederick maryland
Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
I am trying to mount the three wheel weights on each wheel but find that they are too heavy to lift by myself. Wondering if someone has devised a way to handle this via some simple rigging device?
   / m7040 cast iron wheel weights #2
You need a friend with a forklift or forks on a FEL. That is how the dealers do it.
Thanks, do not have a forklift to do this so will try to rig it up with a 2 by 4 8 ft long inserted into the hub of the wheel and use that to lift the ring into position. Will let everyone know how it works out after this weekend
   / m7040 cast iron wheel weights #4
Often we use threaded rod for wheel weights making changes easy!
2011 FREIGHTLINER M2 26FT BOX TRUCK (A50505)
2011 FREIGHTLINER...
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
2017 Ground Hog HD99 Towable Hydraulic Auger (A49461)
2017 Ground Hog...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
Hilti TE 2000-AVR Electric Jack Hammer (A49461)
Hilti TE 2000-AVR...
Lot of 3 Dell Desktop Computer (A48083)
Lot of 3 Dell...
