3-Point Hitch M6040
   / M6040 #1
edgrant
Kubota M6040
The 3 pt hitch on my M6040 drops when the engine is turned off. In addition when I lift an implement the implement bobs up and down. Also, I have no oil showing on the dip stick. Could it be just low oil. Where did the oil go?
Ed
   / M6040 #2
If there is no oil it is not going to work... Fill to the proper level and see how things are...
Oil can leak external or internal... if it is leaking between the trans and engine... it will be in the engine crank case...
If it's leaking externally it will be on the ground... either during operation or after you park it, depending on where the leak is... if you use external hydraulic equipment it may be leaking there...
If you are saying that the 3pt is bobbing when it should be supporting a load the 3pt cylinder is leaking, that's generally a internal leak and you will not loose any oil from that... it is just very un-handy... KennyV
PS. ... DON'T run the engine with low hydraulic oil... you will damage the pump...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A51039)
1989 Freightliner...
2011 Kubota M7040SUD 68HP Utility Loader Tractor (A49461)
2011 Kubota...
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2013 Ver-Mac Solar S/A Towable Trailer Message Board (A49461)
2013 Ver-Mac Solar...
2001 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2001 Big Tex 10PI...
