M5-111 and 15' batwing
   / M5-111 and 15' batwing #1
davidcbaker
Nashville, TN
Kubota M5-111
Well, everything finally came in. Got a chance to put the tractor and batwing through it's paces last night. We have 61 acres. More thoughts on the tractor coming soon, but for now, here are a few pictures. This is the 24 speed ((6+6)X2) hydro shuttle. The batwing is the RC3615.
Great looking rig. That would make short work of my 5 acres.
Let's hope it makes short work of my 61 acres. I ordered an 8' rotary and then sat down and did a calculation and changed the order. :)
   / M5-111 and 15' batwing #4
Just curious.....What ground speed were you able to maintain with that setup and what appears to be ~knee high grass?
I mow a TON that looks just like that. My accounts that get done anywhere from 1-4 times per year.....bulk of my business.
It's really steep--lots at 8 degree slope and some at 12 degrees. I'm in 4WD the entire time. Set PTO at 540 and then in 3rd or 4th (low) as I recall, doing about 3-4 mph. It's not fast. But the machine doesn't bog down at all. The only reason I'm mowing that slow right now is because the terrain is unfamiliar and I don't want any surprises. Thus the low bucket on the FEL. The tractor has gobs and power. Fuel burn is 1.6 gph downhill and flips to 2.4 gph uphill.
   / M5-111 and 15' batwing #6
Wow, thats really good on fuel.
4 MPH with a 15' cutter should yield ~6 acres per hour mowed.
I can do about 4 acres per hour with 51HP and 8' cutter......but still burn through ~2.5 GPH fuel
   / M5-111 and 15' batwing #7
Are you running in ePTO? When I’m going all out I’m in the tune of 5-6 GPH. However, that’s running 5-7 mph. That fuel usage is incredible
Brett
   / M5-111 and 15' batwing #8
That is really good fuel economy. The first 5 hours of usage on my T4.75 with 10 foot Titan yielded a tick under 3 GPH. I was cutting tractor high stuff and waist high grass in steep rolling hills. I was at 2200 RPM and 5.5 MPH. Terrain was very difficult to say the least.
Brett
Nope--standard PTO. About 2,000 rpm in 4th and 5th.
   / M5-111 and 15' batwing #10
Very nice looking setup. Is there an I am jealous emoticon?
2012 BIG TEX PIPE TRAILER (A50854)
2012 BIG TEX PIPE...
2018 PETERBILT 567 (A50854)
2018 PETERBILT 567...
2015 Ford Explorer AWD SUV (A48082)
2015 Ford Explorer...
1 guard rail (A49346)
2016 Chevrolet Traverse LS SUV (A50860)
2016 Chevrolet...
2013 MACK GU713 (A50854)
2013 MACK GU713...
