LX279 PTO won't engage
   / LX279 PTO won't engage #1
bfreegv
Grass Valley, Ca
JD LX279, Ford 8N, Branson 2810
Circa 1998 LX279 with 42' deck. The PTO stopped engaging in the middle of a mowing session. My wife was mowing so I don't know the exact sequence of events.
The switch was replaced a couple years ago. I checked continuity was OK on all the terminals when the switch is operated.
If I disconnect the harness jump 12V directly to the clutch it engages. Clutch winding reads ~ 3 OHMS which I think is OK.
Seat switch shuts off engine so I think it's OK.
Reading about similar problems with other models I suspect perhaps either a safety or something on the board failed as I see "PTO relay" mentioned often but I can't find a schematic for this model and I don't know exactly where all the safeties and other involved components physically are.
If someone has a schematic, knows the locations of the switches, something I've overlooked or any other feedback I'd be very grateful.
Thanks in advance
--bob
   / LX279 PTO won't engage #2
:welcome: to TBN
Send a PM message to member "joecdeere" to check if he by chance has a copy of the service tech manual to send to you.. include an email address so if he does, and can, then you may get some help that way.
Maybe that switch again?
:welcome: to TBN
Thanks for the reply.
The switch checks out with an ohmmeter. The contacts open and close as expected.
I'll definitely send that message, thanks again
2020 Freightliner Cascadia 126 T/A Sleeper Cab Truck Tractor (A49461)
2020 Freightliner...
2017 Caterpillar 259D Two Speed Compact Track Loader Skid Steer (A50322)
2017 Caterpillar...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A50323)
2012 Cottrell...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A51039)
2021 John Deere...
4 BRIDGESTONE 11R24.5 (A50854)
4 BRIDGESTONE...
