LX178 Shuts Off After 15 minutes
   / LX178 Shuts Off After 15 minutes #1
DeansR
LX178
This previous post by another member explains the problem I am having with my LX178. Does anyone have a suggestion? I have also replaced the carb, fuel pump, fuel lines, filter and cap. Thanks, Rob
My LX178 starts fine, runs for 5, 10 maybe even 50 minutes and then stops as if out of gas. It won't restart unless full choke - then maybe runs intermittently and dies. If it cools down for an hour I can repeat the process over again...
I have a new (last year) dealer installed carb, I've checked the gas cap, blown the fuel lines and even blown a bit of air thru the carb after removing the float bowl. The fuel is new, the fuel filter is new and the tank is clean. Any ideas?
   / LX178 Shuts Off After 15 minutes #2
Sounds like you've taken care of the fuel side of things. Might it be electrical? Intermittent coil connection, plug wires, other connections??
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2006 GMC 4500 Bucket Truck with Altec AT200 - 34FT Working Height (A51039)
2006 GMC 4500...
2005 MACK CHN613 WINCH TRUCK (INOPERABLE) (A50854)
2005 MACK CHN613...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A51039)
NEW 2022 Load...
