LucasCav injector pump
   / LucasCav injector pump #1
green1968
JD 2350
Need help with governor spring code on a CavLucas Injector Pump DPA R3448F040, Model 30280 EDG. Type RE 11803. The spring came off the throttle shaft during reseal.
   / LucasCav injector pump #2
Welcome to TBN!
Previous post should answer your question:
Thanks for the reply, it looks the previous post was position 8. On my JD Lucas Cav pump the spring location was in the middle hole on the governor, for my information which number is used to determine position. All other info I have seen there has been a slash prior to position number. Thanks to all
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
2012 KENWORTH T800 SLEEPER (A50854)
2012 KENWORTH T800...
2007 Pace American Enclosed Trailer (A49461)
2007 Pace American...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2011 V.E. ENTERPRISES 130 BBL STEEL VACUUM TANK TRAILER (A50854)
2011 V.E...
12in Backhoe Bucket (A51039)
12in Backhoe...
