Gale Hawkins
Super Member
- Joined
- Sep 20, 2009
- Messages
- 8,234
- Location
- Murray, KY
- Tractor
- 1948 Allis Chambers Model B 1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
Lucas Hydraulic Oil Booster & Stop Leak : Lucas Oil
Add to go to Lowes today to pick up a pipe fitting that I broke off of the backhoe boom with one of the stabilizers after getting it mired down yesterday. Thankfully on the 4th Lowes had the pipe fitting and a #6 Eazy-Out so I to work today. While in town I stopped by O'Reilly's and picked a couple quarts of Lucas Hydraulic Oil Booster.
After adding just a quart to 20 gallons I found the hoe was digging a bit better. I am in a swampy area cleaning out some ditches put in using a 36" bucket trackhoe 10 years ago. It is mainly clay/sand/water which can be very hard to break-out because the bucket tries to create a vaccum when lifting out of the muck.
The tilting occurred because I was able to break-out with more in the bucket and when turned 90 degrees to dump with fully extended boom the BH tilted to the side of the bucket. Since it was only a couple foot off the ground I let down the boom and the tractor set back down flatly.
While more power can be subjective the one thing that got my attention was the sound of the engine. When digging it was actully causing the engine governer to respond. With the JD 310B (1983) I normally dig at 12-14K RPM. More RPM's does not give more break out power.
This my first time trenching. I was inline with the ditch when I got stuck in a major way but over time worked. After that I had to work from one side.
I will watch the result of the Lucs tomorrow.
Does anyone have any good/bad experiences with Lucas Hydraulic Oil Booster?
