LS MT357 - AC Blower Issue
   / LS MT357 - AC Blower Issue #1
Macinnis
St. Louis/Old Mines MIssouri
LS MT3 57 Cab
125 hours or use, garage kept…runs like a top.
I greased everything up yesterday, blew out the radiator and went to work.
it was cool out, so it took a while for me to turn the ac on. When I did, I noticed it was on setting 1, but no air was blowing out of any vent. Moved to setting 2, still nothing, setting 3, nothing. Setting 4…air came out full blast and was COLD. I spent the next 5 hours cycling the ac from off to setting 4 and getting too cold too quick.
has anyone had this happened or have any clue what to look at to remedy this?
Thanks,
Bill
   / LS MT357 - AC Blower Issue #2
It's most likely either the fan switch it's self or there is a separate resistor for the fan speeds. When the resistor burns out or breaks often all that works is the high speed as it is direct wired and doesn't go thru the resistor.
   / LS MT357 - AC Blower Issue #3
Can adjust the temp to add in some warm then you can leave the AC running full with cold + warm to keep it comfortable without having to turn the fan off.
I do this in the winter when snow pushing - keeps the windows from condensating and I can see out all the windows.
Fan switch is the culprit as mentioned.
2011 MACK GRANITE HOT OIL (A50854)
2011 MACK GRANITE...
2006 International 9400i (A51039)
2006 International...
2006 INTERNATIONAL MA045 DAY CAB (A51219)
2006 INTERNATIONAL...
AMCO F42B-3626CS 13ft Pull-Behind Wheel Offset Harrow Tiller (A49461)
AMCO F42B-3626CS...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A51039)
Neckover GL24-2-7K...
2011 Chevrolet Impala Sedan (A48082)
2011 Chevrolet...
