Lost Hyd Power on ASV RC100
   / Lost Hyd Power on ASV RC100 #1
z71hunter
Was cleaning out the tracks on my RC100 cleaning it up to do a service on the machine. Moved it around the yard a few times from the shop to the wash bay and back, etc... When I got in it after pressure washing the tracks the machine cranked up fine but the loader arms are dead. No hyd movement at all no up and down and no rotation of the bucket. The quick attach is working, but the low flow and high flow do not engage. When I move the loader arm joystick around i get absolutely no response, it does not even seem like the pump is engaging. One thing I did notice that I don't believe I have seen before is that when I toggle the two buttons on the top of the loader arm joystick the low flow light switch flashes green. Maybe it always has done this and I just have never noticed it.
To make matters worse, I decided to jack the loader arms up so that I could move the machine back to the shop and I got about half way there and lost hydraulic power to the drive motors. I can hear the pump engaging and trying to put power to the drive motors however the machine acts as if the tracks are bound up or as if there is brake engaged. When I push the track joystick forward or back the drive motors act like they are trying to move but something is holding them back.
The other thing I noticed after checking the machine over is that each time a cranked the machine up it seemed to get harder and harder to crank it. It seems as if the battery is going dead all of a sudden.
Has anyone had a similar problem?
Any suggestions, tips, or things to check and test would be much appreciated.
Thanks
   / Lost Hyd Power on ASV RC100 #2
When the alternator is not working the battery runs down & the electric things start to shut down. I have had it happen before & the alt. is usually the culprit!
   / Lost Hyd Power on ASV RC100 #3
Did you perhaps break or disconnect a safety switch somewhere that will shut down the hydraulics? Did you put a pressure gage in the system to check pressure. I am assuming that you checked all the fluid levels. Is there a shut off switch on the hyd filter?
Do you have a manual?
   / Lost Hyd Power on ASV RC100 #5
It sounds like it's either the solenoid or spool for the operator presense loader function. I had this exact thing happen to mine and replaced both. Usually it's just the solenoid which is not very expensive and hard to replace.
Thanks for all your help. I did finally resolve the problem. It appeared that one of the solenoids (Loader/Brake) shorted out and melted. I replaced and checked ohms on all other solenoids put the power generation block back together and she is working fine now.
The fix was inexpensive the solenoid was about $50 and the spool was $80 but it was a bear to fix. Since the machine was dead we had to get another loader to raise the arms so that we could raise the cab. Then we had to completely remove the floor of the cab to get to the solenoids. Nothing difficult just time consuming.
Thanks to all that gave advice.
   / Lost Hyd Power on ASV RC100 #9
my asv is doing the same thing i run fecon mulcher on it it takes a beaten but first major problem other than heat temp
   / Lost Hyd Power on ASV RC100 #10
I have a ASV RC 100, with a AFE Head on it. I works 10 min. with the head and it hard go left, right or forward. It will also not go up on trailer unless it cools down 30 min. to an hour. Then it will go on trailer.
Changed 3 different oils, need help? Thx
the head works all the time
2004 Ditch Witch RT70M Ride On Trencher (A50860)
2004 Ditch Witch...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
TOYOTA 8FGCU30 FORKLIFT (A50854)
TOYOTA 8FGCU30...
Brown 417 7ft Rotary Cutter (A50490)
Brown 417 7ft...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
