Looking for Info on a Rockhound 5A
   / Looking for Info on a Rockhound 5A #1
mike48130
Platinum Member
Plymouth, MI
JD 4410, 4210 Ford 1700, 550, Bobcat 843
I have a used and abused Rockhound I just picked up this year. Someone started working on the hydraulics, and screwed it up. The pulled "regulator" out of the hydraulic valve part number 6632257 or 6632258. If someone has a 5A that maybe they worked on and took pictures of the valve, it would help. They removed the regulator and replaced it with a plug, so the motor doesn't get any hydraulic pressure. I called Rockhound, and they have no information on it, probably just lack of looking, but must have a pervious PO or something. Anyways, looking for the OEM PN stamped on it to see if I can ebay something close enough to work. Other wise I need to redesign the whole setup to replace this valve block.
Or if anyone knows where to get used parts at would be a great help.
Thanks,
1000 Gallon Water / Chemical Tank (A50860)
1000 Gallon Water...
2015 FREIGHTLINER  CASCADIA (INOPERABLE) (A50854)
2015 FREIGHTLINER...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
2013 Chevrolet Impala Sedan (A48082)
2013 Chevrolet...
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
