looking at l35
   / looking at l35 #1
joea99
Platinum Member
Marbletown NY
Kubota B21, JD 240GT
As may be obvious, I am new to tractors.
I was checking out an L35. under 2000 hours. Wondering what trouble areas to look for. Has new seals, starts right up, no odd noises or smoke (except white puff when raising rpm from idle). Neutral/fed/rev lever seems a bit "mushy" and hard to feel out. ram has some light surface "rust" kinda looks like "stretch marks" on skin. Tires have some weather checking but hold air, apparently. But I am stunned by how expensive those puppies are. Welcome to reality, I guess. Seems to move and dig fine. I can finely control the boom and bucket with little effort. I guess my main concern is that the overflow coolant container is empty. I did not see a hose, in the cap, to the bottom of the container as you do on cars. Normal? I was going to bring some pre-mix coolant with me to fill it and run it again, just to be "safe".
I liked it enough to start lining up a hauler and fill the envelope for the trip.
Comments?
   / looking at l35 #2
I would be concerned about that puff of white smoke and the low coolant. I'm no expert on diesels, but that may be an indication of head gasket leakage or worse.
   / looking at l35
Exactly my concern, tho unstated.
   / looking at l35 #4
I concur. Typically, white smoke = coolant, blue = oil, black = fuel. Could be nothing, could be horrible!
   / looking at l35
Thanks. Keep those cards and letter coming folks!
I really should have checked more deeply then, but it was cold, windy and no auto stores around. And, by that time, I was already "under the spell" and needed to go clear my head before I whipped out the ring. So to speak.
   / looking at l35 #6
I used to have a neighbor who used a L35 in his landscape business. To say that thing was run hard would be a criminal act. It was hammered, yet it always ran. Really said a lot about Kubota quality.
   / looking at l35 #7
The Kubota commercial TLB's are great machines, but many of them have lived a hard life at rental yards, landscapers and construction outfits. Anyone buying used needs to make sure about the condition before closing the deal.
   / looking at l35 #8
Mines only has 450 hrs and runs great and is a very tough built little machine. The only trouble I have had was the levers that release the backhoe attachment got rusted and froze up. They need grease fittings.
   / looking at l35
So. Basically, if I am allowed to fill the coolant tank and can run it at various RPM and loads, and see no bubbles in the tank and no over heat or leakage around the head (and the oil is clear) I should be pretty sure the head gasket is OK?
Except for the tires (still gasping for air and holding my chest over prices) and some cosmetic issues, the machine seems fine. A local guy told me 1900 hours is "getting up there". Is that the general thought?
   / looking at l35 #10
You should look very close at the engine oil as well. They probably have fresh oil in it to sell. Even then you might be able to see a slight white slime in the oil or filler cap if you have a head gasket problem. I would be cautious on this one. It might be fine. But "might be" won't pay for a potential repair.
If it is just a head gasket it could be a simple fix. But I have had cracked heads on other equipment that wasn't. And the fix can add up fast. Good luck to you. And please give us an update.
2017 Claas Jaguar 860 Forage Harvester (A51039)
2017 Claas Jaguar...
UNUSED Black Outdoor Patio Fabric Screen Cover (A50860)
UNUSED Black...
Blue Concrete Test Shed (A49461)
Blue Concrete Test...
UNUSED 48 in. Adjustable Pipe Wrench (A50860)
UNUSED 48 in...
2015 Ram 1500 Crew Cab Pickup Truck (A49461)
2015 Ram 1500 Crew...
Brown 417 7ft Rotary Cutter (A50490)
Brown 417 7ft...
