Looking at 3032E
   / Looking at 3032E #11
My 3032e was delivered last month. Only has about 8 hours, but happy with it so far. Really all I have done is brush hog with a 5' mower and play a little bit. If you don't need all the bells and whistles, I see now reason why it wouldn't be a good fit. I actually wanted it to be lighter than the 3320 so it would be more able to act as a finish mower in the future, while still allowing me to go up in size from the 2320 I started looking at.
Good luck!
   / Looking at 3032E #12
The 4wd shaft to the front axle is exposed and mine has some light rust on it. I house my tractor in a pole barn with open sides and a tarp over the machine, but evidently it has not been enough protection for the axle. Still, it's very superficial light rust and it has caused no problem. I have not caught any brush in it. Since lowering my tire pressures I don't run it in 4wd much anymore.
   / Looking at 3032E
I was wondering has anyone heard of skid unit to cover the 4x4 drive shaft I crawled under a 2012 3038E which I assume is the same as a 3032E and the shaft was partial incased, I guess I am little concerned of damage to it after my last experince with my 2320 I really would like that thing protected even though I do not believe the problem from the 2320 was a shaft problem I believe the problem came from the front causing the 4x4 drive to break off inside the rear. Has anyone had any problems???
2014 John Deere 6125R Utility Tractor with loader (A50657)
2014 John Deere...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
2012 John Deere 7280R MFWD Tractor (A51039)
2012 John Deere...
2007 John Deere TX 4x2 Utility Gator (A49346)
2007 John Deere TX...
2020 MACK PINNACLE (INOPERABLE) (A50854)
2020 MACK PINNACLE...
2020 KUBOTA RTV...
