Loads on 30 amp ACC fuse for 5065e?
   / Loads on 30 amp ACC fuse for 5065e?
I am going to unplug the sensor and try it I just was wondering what else to look at if it doesn't work. I am not positive that sensor communicates with a 30 amp fuse by itself
I really wish I saw a diagram with temp sensor on 30 amp ACC circuit
On my fuse block legend the place that is labeled 30 amp ACC relay is actually a fuse (buss type 30 amp). According to your attached DWG, the fuse should not be energized unless key in run or accessory position. My fuse terminals are hot with key "off". Wonder if ACC relay has failed? I don't see one in fuse block like there is for starter and turn signal? All I know is if battery in tractor with good connections, every 30 amp fuse blows while installing. Don't know where ACC relay is but gonna look for short in 7 pin connector. If I forget about this fuse and circuit, tractor runs fine as long as positive and negative lugs tight.
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2018 Chevrolet Tahoe SUV (A56859)
2018 Chevrolet...
Miller Stick & Mig 3 Phase Welder (A56469)
Miller Stick & Mig...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2007 TEREX ADVANCE FD3000 FRONT DISCHARGE AWD MIXER (A57880)
2007 TEREX ADVANCE...
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
