Tires loaded tires
   / loaded tires #21
my local les schwab is also charging 3.10 per gallon for ringuard - $2.10 per gallong for calcuim but a tube runs about $50. on a 35hp tractor that weighs about 3500lbs with FEL what is the recommended amount of weight that should be added to the rear tires? i was thinking about 250-300lbs per rear tire... is it worth putting any in the front tires? i have been using the FEL without any ballast and it's pretty easy to unweight the back tires, i've found. ;-)
cheers,
bigballer
   / loaded tires #22
Generally, you'll want to fill the rears with the valve stem at the 12:00 position so it's just over the rim. Now look into that thread above that gives tire sizes and subsequently, the # of gallons and weight for that particular tire size. That is the norm...
As far as filling the fronts, you'll find different schools of thought on that. Personally, I filled mine for better traction and stability too.
   / loaded tires #23
cheers,
bigballer
BB,
I found information on how much counterweight needed is the original sales literature for old Ford tractors. They are pretty consistant around 120% of the FEL lift capacity. For my old ford, they want 3500# of counterweight. The tractor is 3800# and the FEL 1400#. Lift capacity is 3000.
HTH
jb
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
(2) 5' FOLD UP TRAILER RAMPS (A57192)
(2) 5' FOLD UP...
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2005 Dodge Ram 4x4 Crew Cab Pickup Truck (A55852)
2005 Dodge Ram 4x4...
